woodman300
- Joined
- Aug 15, 2010
- Posts
- 29
- Reaction score
- 0
96 tahoe stock with 285/75r16 . 107k
ok its time for new tires, i got about 60k and 10 years on these bf goodrich ta ko s and i want to run the same size again on a new set of rims. what i don't want is to have the same problem with the front fender. its not too bad but they rub when i hit a good bump, especially when offroad. i was really upset the first time it happened and i saw the cuts in the tread. cut right into the corners. i will probably have the fenders trimmed a little if i can, i don't know how much room that will get me. the new rims will likely be close to the stock backspacing, and i think i will have to do something with the torsion bars. my question is regarding the aftermarket torsion bar keys like suspension max. they claim to give you the lift without sacrificing the ride quality. i wonder if that is true. i see that they have a key that you can choose how much lift you want. how does this actually work? does it load up the bar or does it change the bar's geometry? i only need 1.5 to 2 " of room. i know i could get this by cranking the stock keys but if i could get the lift with new keys and keep the ride quality, i would go for it. i am not really interested in a 'real' suspension lift because like i said i am not getting huge tires and the wife likes it the way it is now. for some reason she doesn't like the idea of climbing up into the truck, i don't get it but there you go.
what do you guys think about it?
