never heard of a seat belt being called a cop deflector, lol
Since when did anybody start using aluminum studs? Or aluminum lugs? I sure wouldn’t.Sorry the "wheel" is mounted using ALUMINUM studs from the spacer with the existing steel lugs.The spacers come with their own lugs which are also aluminum. Using the stock steel studs to mount the spacer with its aluminum lugs and in turn aluminum studs with existing steel lugs to mount "wheel". The failure occurred at the spacer where the steel studs are mounting the spacer. The steel studs chewed the aluminum allowing the aluminum lugs to walk. And the wheel goes for a tour. If that clarifies for you.
Def aluminumNever seen aluminum studs or lugs on a spacer. I was running 2” spacers on 26’s that had steel studs and steel lugs. You said you used the provided aluminum lugs on the factory steel studs to mount the spacer and then used the factory steel lugs on the aluminum studs that were on the spacers? That definitely is a recipe for disaster.
ExactlyI've ran spacers like that before, but they were only 1" thick (35mm) and made from billit aluminum and had standard steel wheel studs/lugs pressed into them from the back to mount the wheel to.
Sounds like the aluminum they were made from couldn't stand up to the 2" thickness and the large tires.
Yes, the spacers themselves are aluminum I’m not doubting that. Nowhere does it say anything about aluminum studs or lugs. That’s what I do not understand. Never in my life have I ever heard of studs or lugs being made of aluminum, and I guarantee you if somebody sold me spacers with aluminum studs reinstalled, or aluminum lugs, I’d send them back and ask them if they’re out of their mind, especially on a truck or SUV. Maybe others have used them but I sure wouldn’t.Pure aluminum
This is just a technicality, but 6061 T6 aluminum alloy, which your product was made out of, is far from 'pure' aluminum. With more than 2 decades of primary, extruded, and fabricated metal experience, I can certainly tell you that pure aluminum is not really much use for anything, and would be disastrous for this application.Pure aluminum
You are correct. But the existing steel studs against the aluminum spacer.....steel wins.Yes, the spacers themselves are aluminum I’m not doubting that. Nowhere does it say anything about aluminum studs or lugs. That’s what I do not understand. Never in my life have I ever heard of studs or lugs being made of aluminum, and I guarantee you if somebody sold me spacers with aluminum studs reinstalled, or aluminum lugs, I’d send them back and ask them if they’re out of their mind, especially on a truck or SUV. Maybe others have used them but I sure wouldn’t.
But they use steel studs against aluminum wheels all the time plus thousands of trucks run spacers. Something was wr
Only possible other reason could be over toque. Il take a pic of the holes. Thats a huge amount of friction even for lugs to tight. That being said, could a sticky brake pad creating more heat add to the break down? I did notice on that assembly the back side pad was much more worn down.But they use steel studs against aluminum wheels all the time plus thousands of trucks run spacers. Something was wrong with the install.
Exactly. Millions of aluminum alloy wheels out there, bolted on with steel studs and lugs. I want to see pics of these aluminum studs and lugs you’re talking about @01 Hoe.But they use steel studs against aluminum wheels all the time plus thousands of trucks run spacers. Something was wrong with the install.
