Tire rubbing mudflap?
S1W99
Why is my passenger front tire rubbing my mudflap? The tire seems to sit maybe an inch further back than the driver side front tire.
Is there an adjustment? I even trimmed the flap down and it still rubs.
wjburken
Eastern Iowa
When’s the last time you’ve had the alignment checked?
S1W99
S1W99
I've had this Tahoe for several months now. I did a bunch of suspension work so I'm getting the alignment done next weekend. Good point, I didn't think that an alignment would affect it, but hopefully it can fix itGood point, I didn't think that an alignment would affect it, but hopefully it can fix it
Should not be happening. I run 305/50x20 tires without rubbing.
Re-check all of your suspension work to ensure that everything is as it should be, and then get an alignment.
Thank you for posting the solution to your issue. Much appreciated.
brice715
