Tire pressure sensor Yukon XL Denali
Wahpeton, North Dakota
Is there anyway to disable or by-pass the tire pressure sensors. I am going to be installing 23 inch Giovanna's. When I install the new shoes I will be getting "Service Tire Pressure Sensor" and I was wondering what my options are to prevent me having to look at that F'n alarm all the time. Please help guys.
Modded
That Guy
Why disable them lol?
Its not worth it to disable them, I will sell you a set of brand new sensors for $180 if you want.
zach2011
Platinum Member
Please post here if you don't have a 2007+ model.
In any case, if you disconnect the battery, the tire pressure will read as "--" on the DIC, and won't say anything about servicing. I'm coming from an 08, not an 04 so I don't know how that would differ.
Modded
That Guy
Naw it will still give an issue as long as the TPMS is not there, it may not if the TPMS is damaged, then a (-----) sign may appear under the PSI area instead of errors.
zach2011
Platinum Member
Maybe. Idk mine dies all the time lol so I had to disconnect the battery a lot and when I do, the TPM readings come up as "--". It doesn't say anything about servicing it. Of course, as soon as I get mine running again I go out there and do the TPMS reset procedure.
stss95
I am still waiting for someone to come up with a bypass or module that will trick the computer to thinking the sensors are there... it will just take some time.
i am not going to spend an extra $180 to put sensors in my winter wheels, blame firestone and ford....
Jmartin1026
