Tire Monitoring System
JochenWoern
Sacramento, CA
My "Service Tire Monitoring System" is showing on the DIC periodically, thinking one of my sensors is bad.
Is there a way to shut the TMS off? I am not a fan of the system anyhow, as I believe in checking the air pressure regularly.
How can I disable the system?
Thanks in advance.
NathanJax
Vacation Nathan
Jax, Fl
No. You can't disable it. It's just like your air bags, gov'ment regulated for your safety :D
THE YETI
Director of Operations
South FL
Silly question.. But isn't it easier to just click the dash button to check the tire pressure as opposed to getting out to physically check it?
On another note.. Checking the tire pressure regularly isn't going to help if you're on the highway and hit a nail and get a slow leak that could turn into a blowout. You'd get the dash light once the pressure got low enough to be a danger.
I'd keep it. :) well worth it IMHO.
JochenWoern
JochenWoern
Sacramento, CA
Thanks.
On my '04, you can not click through the pressures as I was able to do on my '06. On the '04 it will only show you the light of the pressure is low.
But, I do get your point in regards to keeping it.
THANKS.
Yukongk
NY
You need a sensor? I have 2 that I took off my NNBS wheels bc I have an 01.
THE YETI
South FL
Those aren't compatible with his if it's an 04.
---------- Post added at 11:50 AM ---------- Previous post was at 11:49 AM ----------
Thanks.
THANKS.
Gotcha! On tapatalk so didn't see what year you had. :)
JochenWoern
JochenWoern
Sacramento, CA
Mine is on also, actually on both my cars. I just click the enter button to get rid of the message.
Yes, I know HOW TO and am CAPABLE of doing just that.
However, as I started out in my thread, I like to be able to fix the problem.
dizhai
