Tips on pulling an interior door panel.
withac
Eastern Idaho
Okay, I've pulled door panels before, just look for screws, take em out, slide a panel tool around the edge and pop the clips and start pulling. I've never pulled THIS panel before however. I've got a 2000 '**. Anybody have any tips to save me some time or broken clips or anyting?
Thanks.
Timmy
Brunswick, GA
first pop out themirror cover, handle cover, and lock indicator, there is a screw behind it. then, towards the front of the door is a "plug" that goes through the inner door skin. look under the armrest, there is another screw. towards the back of the door there is a cap with a torx screw under it (t10 i think)
both screws are 9/32.
just pull the panel up and towards the window and unhook the light bulb and the switch panel (unhook the wires, not the panel, there is a screw (9/32) that holds the bezel on.
vsaravia
