jniolon
- Joined
- May 14, 2009
- Posts
- 15
- Reaction score
- 6
2008 Suburban (same one discussed in the towing stuff thread) has developed a "thunk" when you accelerate from a dead stop. Feels and sounds like on the left side. If you pull off slowly, no thunk, but if you press it a little hard...thunk. We put it on a rack and looked all over and see nothing loose, all bushings look good, everything we shook or pried was tight even whether rear end was unloaded or loaded.
We removed the left rear wheel and rotor looking for problems there and found nothing OTHER THAN the caliper seems to freeze to the rotor when the brakes are applied and released.. pads are good.
We removed the caliper and rotor and tried it again and the thunk was there but very light. There is about 1/8" end play in the axle and maybe a 1/16" of play up and down. which is more than spec but I don't think it's excessive.
I read a thread on the information cul-de-sac that said it might be the slip joint on the driveshaft. we removed shaft and greased the slipjoint well...still thunks. My next try will be to have a friend with a scanner hook it up in run mode and check the ABS and such for a problem. Suggestions, comments, SWAGS and experienced fixes are accepted.
thanks
john
thanks
john
