Thrid row seat latch?
nverlast1
Can someone tell me if I can buy this part separate or do I need to buy a new thrid row seat. Mine has rusted and won't move. I have tried wd40 no luck.
1571608037686313044020.jpg 1571608105345552402628.jpg 15716081169262021552108.jpg
wjburken
Eastern Iowa
^^^^^^^This^^^^^^^
PB Blaster or Kroil.
WD-40 is “ok” as a lubricant but that’s about it.
PPV12HOE
NC
[QUOTE
WD-40 is “ok” as a lubricant but that’s about it.[/QUOTE]
Kroil is the best... expensive but worth it... seafoam also makes a product called Deep Creep... but if you can get Kroil get it... a little goes a long way...
Kroil, PB Blaster, ATF mixed with acetone. For big stuff, I use apple cider vinegar and let soak. Since the holidays are nigh, the stores should have it in stock again. I picked some gallons up a few weeks ago.
Those seat tracks rust because they are bare metal and in Florida will rust up right quick.
Floep
WD 40 is a WATER Displace solution, has no lube abilities to speak of. It leaves a very thin coating to prevent water problems. Use products recommended, blast lots on the locking mechanism. Been there done that it WORKS.
rick3645
