those who have beltech spindles
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Ive got a few questions. I am ready to Buy. I am looking to get a 2/3 drop and upgrade to some 22s. I want to keep it family friendly much as possible. Has anyone have any Gripes or problems with alignment issues with their investment? Living in NE the roads around here can go smooth to pot hole city really quick. I want to keep the Front end close to stock as possible and not interfere with turning my 4wd. Thanks guys
soulsea
Bar
Well, mine are coming in Monday so I cannot give input from experience.
But when I was ordering the Belltech 2/3-4 drop kit I considered getting THESE on the advice of a knowledgable member who was of the opinion that they were better as far as alignment.
However I was told by another knowledgable member that that is only a concern for bigger drops ... in his words:
"... the McG ones are shorter and make for a better alignment when one want to drop down to a 3" front drop or more but you are only looking for a 2" front drop so the alignment factor does not apply to you. Outside that, the Belltech ones are just as good."
So I went ahead with the Belltechs.
I really don't know enough to advise anyone, so I'm just passing on what others have passed onto me.
Cheers!
sumo
sumo
rhode island
From what it looks the spindles are pretty much the same size, except the fact that the Hole where the axle and bearing mounts is higher on spindle. I gather that how the Drop is achieved. So if this is the case, alignment not going to be a issue.
soulsea
Bar
Bump to see if we can get sumo some informed advice instead of mine.
sumo
sumo
rhode island
found a comparison shot of drop vs stock
KMeloney
I've got coil relocators coming with the idea that I can drop the front as little as 1" with them. I have the 3"-4" springs in the rear, and I think that the combo (since the rear is very adjustable with the autoride links) will be perfect.
I'll keep you posted. I realize that I'm not going the spindle route that you're asking about here, but thought I'd tell you about a different option.
anton28
You will have absolutely no issues with your new spindles and your alignment specs will not change as they would if you were going with a lower front spring. As far as the ride, the 22's will change your ride quality more then anything, assuming you have 20's or 18's now. I would say that your truck will ride about 90% the same, the other 10% goes because of the stiffer smaller rear spring. I speak from experience. Ive re-lowered my 07 Escalade 3 times LOL. Going with different set ups. spring 2/3 drop, then spindle 2/3 drop, then spindle 3/5. Good luck!
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
My turning radius was not affected by the Bell Tech spindles, mine were great!!! The only drawback to them is not being able to run 17" wheels once installed.
Sweet_N_Low
Blahhhhhhhhhh. Who wants 17's?????:gayflag::imo:
---------- Post added at 03:42 AM ---------- Previous post was at 03:40 AM ----------
If you have OE shocks, Ive been told they tend to bottom easy if more then 1" drop is used
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Wow. Although 17's may not be the preference of some those who are unaware will now know this disadvantage when choosing Bell Tech lowering spindles on a NNBS (It can be done, but the lower ball joint has to be modified - I opted not to do this). Regardless, if anyone besides my wife and I will be driving our Yukon, for example during a dealer visit/paint shop visit, etc. the 26's will be replaced with something much less valuable for the duration. This guarantees the wheels/tires are protected against damage from careless driving, overspray, etc. as well as theft.
Roscoe
Seattle area
I'm glad you posted this because I want to lower my wifes 07 tahoe, but plan on running the stock 17's in the winter. Is the issue the same with the other brands of spindles
dizhai
