Think my engine just failed
soulsea
Bar
Sorry to hear about your troubles Connor.
I see your truck is an 07 ... I don't suppose you'd be lucky enough to still be in the 5yr powertrain warranty?
D
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
So what did they say?
Nothing yet
As goes my luck with anything, no warranty. Truck was originally purchased in March 2006. That puts me 18 months outside of warranty.
Is it possible that it's just bad gas?
Wow that's tough I'm dealing with an engine noise on my 2010 5.3 w only 36 k just got new lifters installed under warranty and the sounds still there. I mentioned the oil pressure only being 20psi at idle and 45 at WOT and they said its Normal but I don't think so.... Just curious what your definition of low oil pressure is??
Bad gas would still be an expensive repair.
Possible but bad gas could also just mean replace fouled spark plugs and be done :shrug:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you are well above the minimum of pressure at those engine speeds.
---------- Post added at 04:58 PM ---------- Previous post was at 04:56 PM ----------
wow..rod knock would involve a whole rebuild no?
not really if the rod journal is undamaged you could like likey change the bearing with some fanangling from the oil pan area.
---------- Post added at 05:00 PM ---------- Previous post was at 04:58 PM ----------
and dom, for **** and wiggles have them change the oil and filter again when they are done.
D
domin8
Just Plinking
Ok. Hopefully there is an O'Reilly's out here. I use a Wix filter for a 2010 Ford Taurus. I know. Seems weird, but that's the deep version of the Tahoe filter. Difference is less than 1 inch and makes the bottom of the filter almost flush with the bottom of the oil pan.
D
domin8
Just Plinking
Breaking news: Rods bearing failed. Stealership is telling me $4600 for used engine. $5700 to replace broken and damaged parts. $6400 for new engine. Since my finances were tapped because of this trip for a funeral, goodbye Tahoe. Hello Impala.
soulsea
Bar
So what, the dealer is trading the broken hoe for an impala? :(
NathanJax
Vacation Nathan
Jax, Fl
WOW!
x2
so what are you doing? trading in the tahoe with a blown motor for the impala?
I think I'd get a malibu before an impala.
CKendrick
