thermostat postion
felskee
is there a certin way to set the thermo? if so then what way?
ntxstallion
Do you mean "set" as in place it in or "set" as in tempertaure.
felskee
felskee
as in the way its pointing. for it to open and close properly.
ntxstallion
Oh ok I thought so. Will get you a diagram for it in a second...........
Should be small side down. As in this pic.
felskee
felskee
well i mean the direction. i kno the pointy part goes up. but i was driving w/o a thermo and it would stay cool till i got on the freeway. so i decicde to put on in. i put it in(no specific way) and when i drive it anywear it starts at the lowest and climbs fast past 260 then comes down and repeats. ive tried all thermos and same result.
ntxstallion
My car had the same issues and turns out that the fans were bad.
felskee
felskee
its the clutch fan? cause i removed it and put it back on after i swaped my heads...
felskee
felskee
well that is a possibility. cause were redoing the intake gasket today and replacing the radiator from a 1 core to 2. only cause the original has cracks in the plastic.
retorq
Kingman AZ
What heads did you put on?? 260 on the gauge is dangerous seeing as how that gauge is reading head temp on the drivers side head, that is usually the cooler of the two.
retorq
Kingman AZ
It really sounds like a Vortec bypass issue ... did you hook up all the coolant lines?? The one form the front of the intake to the pump is important on those ...
mfinta
