The Perfect Tune Up
19Yukon97
Texas
plugs, wires, rotor, cap, fluids, maybe the spider injection kit if you want to do alittle more work
E
Eddy
Texas Panhandle
What About Cleaning The TBI? Replacing PVC Valve, Serpentine Belt? Coolant And Vacuum Hoses? Manifold Gaskets? ..
retorq
Kingman AZ
The manual says to replace the heads, intake, head gaskets, intake gaskets, cap, rotor, coil, fuel pressure spring, fuel pump, water pump, transmission, thermostat, remove EGR, replace the chip, plugs, plug wires and O2 sensor at exactly 185K.
jeff2007 Yukon
