tahoe z71 with leveling kit and stock wheels with 285s? pics please
Zed 71
Pacific NW
That is not bad at all. What size tires did you end up going with? Since I have the LTZ rims (20") I don't know if I should stick with the 285's or go with the 295's....:shrug:
Depends if you offroad and how much trimming you are willing to do. I flex the suspension and had to trim ~2 inches from the from bumper valence.
InTruckDesign
SW CT,
TexasTahoe, I would go with the 295/55/20's with the factory wheels they should clear with no trimming. I run 305/55/20's on aftermarket wheels and had to trim quite a bit in order to not rub when I go offroad.
Yeah that sounds about right..and I am pretty sure that is what I will go with. Thanks!
crdavis4
boroblack
what is the aspect ratio on your nitto's
look like 285/65's???
i'm wanting to do a simialr set up but i have the 20" rims and i'm trying to find out the maximize tire height i can get to. did you have to trim any?
bolo1g2
So if i may ask a quick question, it seem like the CCM 2007-2009 Chevy Tahoe GMC Yukon 2.5" LEVELING LIFT KIT or some leveling kit is necessary to go with LT285/70R17 tires? I like the BFG AT but just wanted to ask about whether stock height works for a 285 tire?
UofMZ71
Yes, leveling kit, if you dont want to trim the wheel wells.
No leveling kit, you will have to trim but should fit
progress
Zed/07Burb, how do you guys like those new Nitto TerraGrappler M/T's? Was looking at a set for my 09 Tahoe, are they decent on road? They look plenty aggressive enough for off road.
Sorry to bump an old thread, just curious.
Zed 71
Pacific NW
The tires are great and I would buy them again. I have ~13k on them and they are wearing well (rotated 3 times now). I am running them at ~45 psi.
I would recommend them with a few caveats...
1. They are heavy so expect lower mpg.
2. They do "sing" at speed. I do not think it is that loud compared to other mud terrains. IMO the sound level falls in between ATs and MTs.
3. To maximize the tire footprint on the ground and also tread life, be prepared to run the pressure at ~45 psi. The combination of E load rating and relatively higher pressure stiffens the ride. I like it because it rides like a truck should, but those getting them for looks might not.
Yes these are to be expected, but I have seen some people (assuming noobs) complain about this.
Good luck and post your updated mods.
SouthernGent
Zed...your Tahoe is awesome. If you get a chance would you mind posting a pic of the side straight on? I have the LTZ rims and wanted to do a photoshop on it to see what they would look like with the tg m/ts. Thanks!
Ha. I have the Z71 rims and and I wanted to put the LTZ on mine.
Kegger87
Hey guys, first time poster. I've got a 2012 suburban and I put in the rough country 2" leveling kit about a year ago. This is the leveling kit that goes underneath the strut.
I was thinking of bring the front end up a little more. Perhaps 1 more inch. With a strut spacer on top.
Wondering if anybody knows if it is possible to do so without having to get different upper control arms.
Any help is greatly appreciated.
Thanks in advance!
DStarr02
Thanks in advance!
What size wheels do you have? Also what trim? Z71? 4x4? Suspension type? Need this to know exactly what you can run. Also are your wheels stock width and offset?
MichaelSE
2010 2500
Tucson
Some people have done 3" levels on 4x4s but it's sketchy. I would not recommend with the stock UCAs.
sanco
Chicago
20180507_024820-jpg.198896
20180507_024811-jpg.198897
20180507_024729-jpg.198898
20180507_024721-jpg.198899
20180507_024654-jpg.198900
img_20180506_104156_908-jpg.198901
mine isn't leveled but its a 285-70-17 on firestone destination MT tires
Fir_Na_Tine
2007 Tahoe 2.5 front and 1 inch rear CCM Level. On P285/70R17 Falken Wild Peaks AT3 and stock wheels 20180610_185045.jpg
CrackerJack135
