tahoe projector retrofit.
a4edwin
ny
I want to do the projector retrofit on my 03 tahoe. I want to know what part numbers or model I would need to make this happen. I did a search with no avail. Only thing I found was the one steve meade did on his truck but he doesn't mention what parts he used only where he got it from
A
a4edwin
ny
Thanks Nathan I read thru those but it's not what I'm looking for I want to retrofit into the crystal clear headlights for the tahoe. The height on the yukon and tahoe headlights are different.
NathanJax
Vacation Nathan
Jax, Fl
I would imagine the projector parts would still be the same.
Pachanga02
Ny
Wow he made that look easy. If it were only that fast and easy.
YukonXL04
The Riverboat
Arlington, TX
Those are mini h1 projectors. Variety of sources for them. Mainly theretrofitsource.com
Or the generic version from amazon or ebay.
blurred
Puyallup, WA
I have recently finished mine up and I ended up using the TSX projectors from theretrofitsource.com along with some shrouds that I picked up off ebay.
I used the $75 pair of headlights/bumper lights from ebay/Amazon and cut the back off the low beam housing so that I could fit/bolt the projectors in place and cut out a flat metal bracket that was JBWelded to the back of the housing. I bolted the projector to this bracket and then sealed the whole thing up.
I had to do some trimming to the shroud (top and bottom) and very slight trimming to the projector housing to get it to fit inside the housing, but I think it turned out well. Cannot post any photos at the moment but they are in the build thread in the Under Construction section of the forum.
GS Audio
