Sway bar options
GMT800 2005 Tahoe Z71
Navy Supporting Member
When I did my rear springs, at same time as the sway bar kits, I replaced them with the Moog 81069 springs. IMO, I like it stiffer but has softened a bit since new because I corner very hard at all times. The feeling is very satisfying.
After driving around with the new bars it is very much a different vehicle. It's body roll is significantly less and going around the corners is a lot more fun. I think it might be just a bit on the firm side. I think most of that is the new springs all the way around which will hopefully soften up a bit as I get more miles on it.
I ran across the installation instructions for my Nolathane bars yesterday and saw that they had a pic of a rear bar showing three holes in it with firmest to softest settings. Did you have this with yours? Now I'm wondering if the Nolathanes really are re-boxed Hellwigs without the end links and the "medium" and "soft" holes chopped off.
My Hellwig rear sway bars have 3 holes in them as well.
From what I see at the Nolathane web site, they make both single hole and 3 hole rear sway bars.
I was comparing Hellwig's and Nolathane's instruction PDFs last night. They're certainly different. I didn't know Nolathane offered both. So that explains it- they must use the three hole instructions for both versions.
johnsonwillie199
