Sway bar inquery ...
retorq
Kingman AZ
Does anyone know with 100% certainty if a 4x4 rear sway bar will bolt up to a 2WD rear?? My buddy has a 96+ that had some damage, the rear bumper and sway bar are mine if I want them, I don't want to rip it out if I know for sure it won't fit, know what I mean. :hands:
foreverfalcon40
Dude 6-bolts and you have a sway bar. While your a it upgrade to poly bushing. I had a sway bar from a 2 dr into my 4wd bet you can do the same! Difference will be night and day since your truck isn't equipped with one.
ocelot
Kingman, Arizona
my 2 door tahoe(4wd) didnt come with one i guess its time to change that any recommendations for an aftermarket one or find a cheap stock one?
992dr
Eastern N.C.
retorq,
If its a freebie, its worth it. You can "make it" fit. Though, I'm pretty sure it'll work.
ocelot,
I have a Helwig rear bar, completely bolt on. Well worth it in my book. You could always go to a local pick-n-pull and try to find a stock one, not sure how much luck you'll have with that though.
Redhoe01
The BDG
Forney, TX
So the two doors do not have a sway bar from the factory. Sorry, new to this truck but just assumed it had one.
johnsonwillie199
