Suspension Compatibility
Dustin Jackson
The GMT900 suspension is obviously very different from the GMT800 suspension but recently I read that all Tahoe parts from 07-2020 are compatible.
Is this true?
If so that would open the possibilities
Trey Hardy
Is this true?
My lift kit and coil overs and control arms came off a 2018-2020 Silverado & gmc at4
And I’ve seen people put 2020 breaks on a 07
Everything is pretty much the same
Marky Dissod
The GMT900 suspension is obviously very different from the GMT800 suspension ...
Largely due to the differences between recirculating ball vs rack & pinion steering.
Which makes me wonder how similar the rear suspensions are between GMT800 & GMT900 ...
but don't let this interloper hijack your thread idea ...
Dustin Jackson
Dustin Jackson
@Trey Hardy I think you were the first to bring it to my attention. I want to understand how similar they are, I saw some beefy boxes control arms that said they were compatible 2007-2020 so far I feel confident the struts and control arms are all the same
@Marky Dissod In my research the rear suspension of the GMT800 and GMT900 is identical.
Trey Hardy
Actually the rear suspension is the same minus the air shocks and what not but I’ve put lift springs from a 09 in a 03 Tahoe and the trailing arms and panhard bar are the same sway bars the same
From what I’ve worked on seems like the rear suspension in the Tahoes from 99-18 are about identical
Trey Hardy
Besides the break upgrade what are some “upgrades” you were thinking about man?
I want to do the 2020 breaks on my Silverado and swap in a caliper style 14bolt rear end
Dustin Jackson
Dustin Jackson
@Trey Hardy My Tahoe build "is complete" so I have no real need right now but In 3-7 years I would like to redo it.
It seems like most of the good kits for the GMT900 were discontinued so I was hoping to find luck in parts made for some of the "current" generations of GM SUVs.
The lift kit that Tozan has is a 4 inch lift kit from Rancho and it includes rear control arm drop brackets and a bunch of other goodies to lift it 4 inches in the most correct manner. I have yet to see a more thorough lift kit.
Trey Hardy
Pro comp and fabtech make good kits with the rear drop brackets and if not I know you can order them through them because I had to do so with my Tahoe to get rid of the high speed vibration coming from the rear end
Did a adjustable panhard bar with the trailing arm drop brackets and haven’t had a issue since
Dustin Jackson
Dustin Jackson
@Trey Hardy The problem is I only want to lift it 4 inches and most companies just use longer rear control arms instead of the drop brackets which might be fine but a goal for my next build would be to accomplish my ride height while maintaining near factory control arm angles.
Trey Hardy
Here’s some pics when I was researching my rear lift
Can’t find the part number for my rough country rear trailing arm drop brackets but if you reach out to fabtech pro comp or rough country and you can buy it separately
Trey Hardy
Looks like a nice kit
Has everything my fabtech had with it as far as the front end goes
Again you could run any brand lift you want and could always buy the panhard and trailing arm brackets separately to get it all right but I get that if you get a lift it should come with everything included with it but for a 4” lift not many company’s add the brackets until you get up to 6”-7.5” lifts
drdude
Gmt 900 uses coil overs, gmt800 has torsion bar suspension. The front as far as lca won't work. You can do a composer conversion though and brakes do work. Alot of people will swap brakes do to.the gmt900 being bigger.
are you surrrrrrre..:fish_h4h:
AllyNJ
