Suburban towing a Suburban
Pyramid_Head
Hey everyone.
As stated, I would like to know what I need to do with my 2011 Suburban LT 2wd to tow another Suburban (2013 LT as well). I have bilstein 4600 all around, 2500 springs, Hellwig front and rear sway bars, but still have the stock trans, stock torque converter, and the relaxed 3.08 gears ratio from factory. I also am shopping around for a trans cooler, and a trailer brake system.
My brother's 2013 Suburban torque converter died and wants to tow it to his new home in North Dakota (he lives in Rosamond, CA at the moment). I told him that I would do the necessary upgrades to tow it.
I'm aware they it would be cheaper to just swap out the necessary parts and rebuild his transmission, but he blew his cash on getting the home and only has enough for a uhaul, plus, it's my opportunity to upgrade parts! I'm planning on keeping it for a while.
Marky Dissod
... would like to know what I need to do with my 2011 Suburban LT 2WD, to tow another Suburban ... still have the stock trans, stock torque converter, and 3.08 from factory.
Any way you can upgrade to 3.73? 3.73 is OE for GMT900 pickup trucks' towing package.
2500s have leaf springs. Since you have highway gears, leave her in 4th for the run and use Tow/Haul of course. Use a trailer with a weight distribution hitch and anti-sway or a U-Haul with its surge brakes. Pick your favorite trailer brake controller if you're not using a U-Haul with the surge brakes. Change your transmission fluid now if it has more than 30K miles on it or change it when you get back.
j91z28d1
if he's got enough for a u haul making the trip, tow it with that. it won't even know it's back there and save the wear and tear on your truck.
as for mods to your truck, my 2 cents is how much do you plan to tow with it after this one trip? if not much, it doesn't mark a lot of sense to me to build it into a tow rig.
just change the fluids before you go and after you get back. watch for over heating, if it's over heating just go slower for a while. might be a longer trip, but it's only once. few hours longer isn't worth a ton of one time tow mods to me?
Pyramid_Head
Pyramid_Head
That's the thing. He wants to reserve a 20ft uhaul box trailer, but he has a lot of stuff to pack. Things he's going to load in the box truck is his harley, 2 big sofas, washer dryer, dining table with 6 chairs, arcade, living room table sets, computer desk, 3 beds, a couple of dressers, guns and ammo, tools, dishes, a couple of TVs, clothes, plus, he's going to tow his daughter's car (crv).
Also, I don't mind the mods. I'm eventually going to buy a small farm in either Idaho, or Wyoming, so I will need something tough eventually.
j91z28d1
ahh if the spot is already taken, it is what it is.
even thou I might tow the crv for him over the suburban haha.
if you'll use it, do it up then. most of the tow mods are good to have if you're going to use them.
there's a very long tranny cooler page around here somewhere that's good a good read. depending on your mileage, make sure you've changed those plastic heater core T's out of you haven't. they have a way of breaking at the worst times.
if it's high mileage, I might think about replacing the radiator too. there's a DENSO one the guys like, I believe it's 150$ and a 1.25in core. so bigger than stock, also has the oil cooler in it, incase you decide to buy the oil lines and run those too.
I know nothing about weight distribution hitches or if you'll need one, but sounds like you don't have the air bag level option, so if you find it sagging a lot, there's good info here on those too. I'd try my best to get it test loaded up at least a week before you gotta get on the road with it. give you time to order parts if you need something.
strutaeng
Dallas, Texas
I'm guessing you will be over the towing capacity, both in GCWR and maybe GVWR. For sure on the pin weight.
The towed Suburban weights maybe 6,000 lbs, plus another 3,000 lbs for trailer? Check your gear ratio and your owners manual for what your rig is rated. Weigh everything.
Trailer brakes are an absolute must. I believe the owner's manual requires a WDH for anything over a specific weight.
Largest transmission cooler would be ideal. Tow in 4th or 5th, can't remember what's recommended for the 6L80?
We can't do things for you over the Internet. Use common sense and be safe.
Good luck.
intheburbs
SE MI
I call the 3.08 the "soccer mom gear." It was a late add by GM trying up their fleet mileage for CAFE. If you look at the towing ratings, the 3.08 trucks are limited to 5,000 lbs of towing. The 3.42 trucks aren't much better at 5,500 lbs. The key is the heavy-duty cooling package with the 3.42 and that gets 8,000 lbs of towing.
If it was me, I'd tow the Suburban with the U-haul, and rent a dolly to tow the Honda with your Suburban.
Save your money to upgrade to another Suburban if you want an actual tow pig.
Marky Dissod
The key is the heavy-duty cooling package with 3.42, and that gets 8,000 lbs of towing.
3.73 will make things easier on the transmission, and improve both stop'n'go MpG when unladen, AND towing MpG.
The gear was available for Silverados & Sierras, so it's not out of place.
If you also get the TCM reprogrammed, the 6L80E will last MUCH longer before it needs a rebuild,
even if you avoid making it any more fun.
intheburbs
SE MI
You don't get to have your cake and eat it, too. Changing ratios is always a give/take. Yes, 3.73 would be better for towing. 4.10 would be better still.
But the 3.73 will yield LOWER mileage when not towing. Again, that was the whole point of the 3.08 - better mileage to help with CAFE.
3.73 = higher engine rpm while cruising = lower mileage
Marky Dissod
Depends on which cake you want.
Changing ratios is always a give & take.
No it isn't, not always. Don't worry, I'm about to explain it.
Glad we agree on that.
GM does too, by the way, but GM saved 4.10 with 6L80 for the heavier-duty stuff where HIGHWAY MpG was of less importance than durability & tow rating.
But 3.73 will yield LOWER MpG when not towing. Again, that was the whole point of 3.08 - better mileage to help with CAFE.
Although absolutely true for highway MpG, especially if one prefers to drive OVER 65MpH, it turns out to be patently false for stop'n'go traffic.
CAFE's MpG tests feature anachronistically sparse traffic, featherfooted accelerations, and Nixon-inspired top speeds.
Ever bother to study the gear spreads for the 4L60, 6L80, 8L90, & 10L80?
Their final gears are 0.7, 0.67, 0.65, & 0.64. 4L60E has 1 overdrive gears, 6L80 & 8L90 have 2, & 10L80 has 3.
Their 1st gears are 3.06, 4.03, 4.56, & 4.7. 4L60E has 2 underdrive gears, 6L80E has 4, 8L90 has 6, & 10L80 has 7.
More gear(s) is (are) improving stop'n'go MpG, towing performance, towing MpG, and durability / longevity.
Gentle drivers who don't speed on the highway will not lose much MpG. If anything, they'll drive even more gently!
Leadfoots will gain SMILES per gallon, plus durability if not longevity.
Any MpG sacrifice will not be as bad as feared, especially for gentler drivers.
Small price to pay for better city MpG, better towing MpG, & better longevity / durability.
Fu'h CAFE.
4.10 with 4L60. 3.73 with 6L80.
mikez71
So you're saying 3.42's with a 10L80 be about perfect?
I need to do this fuel saver mod because I do all city driving, terrible mpg. (Tell your wife! it's true!)
I'll be so happy if I ever get out of 3.08 land...
Marky Dissod
So ... 3.42 with 10L80 would be about perfect?
10L80 has so much / many forward gear(s), in THIS case, 3.42 might cross diminishing returns?
In the specific case of the 10L80, my guess is, it'd need BIGG tires for 3.42 to improve much of anything,
because it has 7 underdriven gears to use to maximize stop'n'go & towing MpG.
4L60 needs a custom rebuild for serious work and play.
With 4.10, the 4L60E works and plays better, and will last longer between rebuilds.
6L80E's weaknesses are hinted at by how GM programmed it for use with the 6.6L LGH DuraMax.
With 3.73, the 6L80E works and plays better, and will last longer ...
3.73 wouldn't help the 8L90 as much as the 6L80E, but it'd only hurt highway MpG a lil bit, if anything at all.
If anything, it'd be able to spend more time in 6th & 7th on the highway.
Pyramid_Head
Pyramid_Head
Although we all agree on f'uh CAFE (statistics back it up), I'm totally up for 3.73 gears. I mean, I live in 3000ft elevation and I just average 12mpg wussy peddling everywhere (I baby my torque converter). I've also installed a new oem water pump, replaced all coolant, new air filter, new spark plugs and wires (all oem), reinstalled my oil catch can, installed new front disc brakes and pads, rebuilt the whole front and rear suspension 2yrs ago with oem parts, and I recently did 3 fill and drains, installed a new oil strainer, also replaced rear-end oil.... I mean, I did a lot on this truck, and I'm loving it!! It presently has 127k miles on it. I also have the range dod disabler.
R467X
I third and fourth the rent a uhaul and let them deal with the wear and tear.
If you want a suburban tow rig, look at eBay listings. There are Duramax swapped suburbans that go on sale from time to time. Those things are suburban tow monsters.
Marky Dissod
Although we all agree on f'uh CAFE (statistics back it up), I'm totally up for 3.73.
I mean, I live in 3000ft elevation and I just average 12MpG wussy peddling everywhere (I baby my torque converter).
It's a safe bet that the CAFE MpG 'road tests' do not include steep hills.
Those who only drive on flat plains seem to tolerate the axle gears CAFE forced GM to give them.
6L80E + 3.08 + long steep hill ... the greater the elevation change, the better off with 3.73.
I don't disagree with using a different dedicated tow rig, but
If you want to turn YOURS into a tow rig, more axle gear can't hurt.
K2 Kaiju
The Depths
I also say tow the burb with the Uhaul, and you pull the CRV or another trailer with his belongings. I have never used one, but could one use a tow bar for the burb? I know the stock tow limit on my 18 burb was only 6k...
B-train
The way I see your post title.......LOL
nothing more to add that hasn't been mentioned.
Pyramid_Head
Pyramid_Head
Oh... I see... well, I added some type of spring 2 yrs ago that lifted up the suburban about 2-3 inches. Here is the link to my thread install from almost 2yrs ago.
Pyramid_Head
Pyramid_Head
Very true. I'll relay the plan to my brother. Thanks again everyone for your input.
X-ray Nerd
