FrankU
Well it has started. Now with the L9H conversion the 8.5 rear I have noticed has lots of play in it. The 8.5 rear end was marginal in strength before the engine conversion , IMO the 8.5 is a weak little rear to start with. So it begins........
Two questions if I may.
From checking the Forum archives the upgrade is using a 9.5 AXN 14 bolt rear with GU6 3:42 and a G80 posi am I correct ?
This may be a direct swap except the rear axle driveshaft length ?
