Stay Away From The 2-3" Rough Country Suspension Lift
StormPackie
hanford, ca
Hey I just got this lift an so far I havnt had any problems. I've seen the first this post was set was 09 so maybe they had adjustments to it considering I go it about a month ago. But I'm going to look thru this thread an I'll keep tabs on my lift, but this won't be my only lift this is just a start.
---------- Post added at 01:53 PM ---------- Previous post was at 01:41 PM ----------
StormPackie
hanford, ca
Oh an idk if he took off his overload springs?
an update the only problem im having with this lift is the galvanized spacers the shock cradles on inside the brackets. but other then that its solid an i also currently got a stabilizer as well an it helps so much more.
StormPackie
hanford, ca
StormPackie
hanford, ca
See mine look nothing like that, but then again idk I went to a off road motors port place an they installed it but here's my front shocks
GM iraqi
Oh my god thank you so much friend
Because I was planning to have one but with the 6 inch lift and it will cost me around 2k because I live in Iraq and the company is obviously in USA
drakon543
Ive used rough country products before and they are what they are (get what you paid for). They sell most of thier kits cheaper than others due to inferior parts and design. They aren't meant for serious offroading mostly due to inferior brackets and poor angles on steering components. Not that they are bad kits, they get you the added height and some of thier kits will also increase articulation. However a solid lift shouldn't be built from spacers and blocks as alot of thier kits are. Drop shackles, lift springs, better coils and proper steering component geometry are best. Blocks in the rear can add stress to the ubolts and add the possibility of your rear jumping during wheel spin due to "axle wrap". Also most of rough country's taller coil springs are single rate springs and depending on the setup can give you a bumpy ride. Lastly poor steering brackets and bad angles can increase the chance of "bump steer". Outside of those facts if the truck wasnt my daily driver and i wanted a cheaper suspension lift i would buy thier products again.
Jbobch
Hey. I actually purchased this kit at the beggining of 2016 and I stalled it. I didn't install the differential drop that came with it as I thought that was way too much for a 2 inch lift. I only installed the torsion keys, upper control arms, shocks, shock relocates, and blocks in the rear. They have upgraded this kit from the way you have it. They have upgraded the shock relocators to where it doesn't dig in to your cv boots. I have had this kit on for close to a year now and have yet to have any problems. And I didn't even drop my dif. Yes it rides a little stiffer but you can expect that when you crank your torsion bars. But as the wear and tear part I haven't had any trouble at all so far. I was real hesitant of getting this kit due to this post. Buuuutttt I ended up buying it and I love it I didn't want anything drastic. Oh I only cranked my new torsion keys to 2 inches any farther and the differential drop is needed to prevent cv axle problems. I just thoughthink I'd throw that side note in. Thanks guys and I'm sorry that happened to you man.
1BADI5
DMV
@Jbobch Do you still have the differential drop by chance. I'm going to be lifting mine (more) soon and need a differential drop.
If you have it and would be interested in selling it, let me know. Thanks!
97Mistake
Going to try and revive this...looks like all around this is a decent kit now. I’ve always liked the stuffed look of a bigger tire with a short lift. Anyone know if this can fit 35s ok? Or should I stick to 33’s with a 10 in wide wheel? Pics would be cool, I’ve scoured the internet and haven’t really seen any.
wwiizz
