standard Black bear tune.
dre
can anyone who has done a standard BB tune with 24" wheels tell me about their results? was it noticable .........please explain........
blueflamed03
Oklahoma
I did with 20's, but i bet with 24's you REALLY lost some power huh? Another thing to consider, is gears....what gears do you have now, and what size tires?
D
dre
no i do not tow.....and for gears i don't know.......its a stock 2007 chevy tahoe.......its lowered 2/3 and a C.A.I. is the only performance upgrade i did....... thanks for trying to help me out
chistoso
Arizona
I had my BlackBear before I had my Supercharger and I had 24's and the difference was very noticeable. One of the best investments I did besides the SC. Can't go wrong with BlackBear. I ran stock 3.73's for a while and towed a 25' Master Craft and it did well with the combo. Now I run 4.11's It has pros and cons it just depends on you..
D
dre
can you explain more about the pros and cons .....................thanks
Zed 71
Pacific NW
^ To provide more input, what are your goals, expectations, and budget?
BB tune regardless. Gears will cost quite a bit for parts and labor - need to replace the differential gears at both axels.
chistoso
Arizona
Gears? With the 4.11's it feels lighter, stronger but I get a lower gas mileage than with 3.73's
D
dre
wow u guys have been helpfull.........im not planning on touching my gears......whatever the tune does for the truck is good enuff.......i just want my tahoe to have that edge when i step on the gas......besides its a daily driver....
---------- Post added at 07:26 AM ---------- Previous post was at 07:24 AM ----------
the tune is gonna run me about 450.00 i just wanna get my moneys worth......i wanna see a big difference..
Zed 71
Pacific NW
^ Are you sure $450 for the tune? What are you getting?
You say you want a big difference. Do not expect a large increase in power. The main thing is drivability - better throttle response, better tranny shifting, a little bit more power, and maybe a little bit of fuel economy (if you can keep your foot off the skinny pedal :).
What mods do you have engine wise? It would be better to have an aftermarket intake, at least change out the muffler (Magnaflow or Corsa), and remove the resonator (if you have the 5.3L engine) to take advantage of the tune.
D
dre
450.00 cuz i wanna keep my ecu etc.......so i can return to stock for dealer issues.....i do have a cai and did change the muffler out cant remember which one it is (either magnaflow or flowmaster). didnt remove the resonator..... should i .......
thanks for taking the time to inform me......
Zed 71
Pacific NW
Yeah that is a good idea to have a stock ECU. As far as the resonator, it is a point of restriction so for performance wise (although minor) I would replace it. But it will get a lot louder since you have an aftermarket muffler.
FYI, when I took the resonator off (have the Magnaflow), it got a lot louder inside and out with drone at ~2,500 to 3,000 rpm. I kind of like it though...
D
dre
zed once again thanks for your advice and knowledge
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I had a Predator programmer while running my stock 17" wheels, then went back to stock and got a Blackbear tune after installing my 26's. Performance was improved with both however the difference I noticed was that the Blackbear tune's increase in performance was noticeable from idle up whereas the Predator tune was not until 3000RPM and above. As others have also mentioned, drivability is another plus of the BB tune... transmission adjustments between the two tunes mentioned above are also a night and day difference. Blackbear made my transmission shift and respond to throttle position the way it should for best performance and drivability, which was not noticed (or not included) with the Predator tune. I never made it to the track but I'd be willing to bet that my Yukon with the heavier 26's and BB tune would have a quicker 1/4 mile time than it would have with the stock wheels and Predator tune.
CKendrick
