SunlitComet
OBS Jedi-Do Good
you likely had some hot spots on the old rotors. No wheel should require you to cut off the balance weights. perhaps on the off chance you might find a drum with a weight that is formed flatter but longer as needed to make things work. I would do the rear first since you need to and go from there.
