Squealing Brakes
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you likely had some hot spots on the old rotors. No wheel should require you to cut off the balance weights. perhaps on the off chance you might find a drum with a weight that is formed flatter but longer as needed to make things work. I would do the rear first since you need to and go from there.
jbuck07
texas
Yeah, since I changed the front rotors there has been a huge improvement on the braking. Do you have any suggestions for the rear drums and pads?
Sent from my iPad using Tapatalk HD
SunlitComet
OBS Jedi-Do Good
i only use ones from makers like delco, raybesto or bendix for drums or rear brake shoes. The last refit used resurfaced raybesto drums and bendix r473 shoes, cylinders and hardware. I have a 4dr so I have 11" drum system.
jbuck07
texas
Sunlit, what are your thoughts about the Summit Racing brand brake drums? They have a complete rebuild set with drums, pads and the inner components for a really good price almost too hard to pass up. From experience, I have found that the summit brand is mostly just a rebadged name brand. For instance, I bought a summit air filter and when it came in the mail, it was actually K&N filter. I'm not sure that would be the case with the drums tho. Just asking your thoughts...
SunlitComet
OBS Jedi-Do Good
I noticed the re-branding too. they did that on the SSBC rear disc conversion for Tahoe. I would feel comfortable with it if I can be assured about the quality and make/model of the parts. You have a link please?
ShortySStahoe
FL
Feels like driving a school bus...Any input?
I have had a lot of noise coming from the rear drums. They only make noise when they heat up. 15 min into driving and braking. I have replaced the shoes and it still screams. They said might emergency brake might be loose and rubbing on the drums..... They wanted 400 to fix the problem. No thanks, I can get a whole disc brake conversion for a few hundred more. Anyone have any input on the squeaking noises?
jbuck07
texas
Just ordered that rear brake kit from Summit. I'll let you know how it turns out
jbuck07
texas
Will do. I live overseas so it takes a few weeks for shipping from the states. Sunlit, is it fairly easy to replace the rear brakes? I've never done it before...
Rme76
