Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have 2011 tahoe with bose sound system. I loved the sound before installing my dnx6990 with gmos 100 adapter. I tried playing with the settings of the audio but it still sound bad. Any tips
No bass at all no matter how high I put the bass on. I also enabled the sub woofer to see if that helps. but it doesnt. also the sound itself sounds ok at low volume but at high volume it sounds really really bad. like I cant understand the words being said and still very low bass.
Your high pass filter may be on too high.
Look for the high pass setting and set it to between 60hz and 80hz.
I have a non-Bose system like you with Pioneer door speakers, a separate amp and sub, and a Pioneer head unit.
It sounds far better than stock even with the sub off.
I made a mistake and just realized it.
I meant your low pass filter should be in that range if it has a setting that adjust the low pass for the door speakers.
all hp/lp filters should be set to off/through. the bose amp does all of thison its own. you need to send a fullrange signal from the head unit to the bose amp.
well I found the problem. its in the GMOS100. I had to turn that white thing with the screw to increase volume. I dont know how that effected it but it sounds way better now.
so I should set everything as through?
Btw how do I know if the amp is working. because I have a feeling I got the wiring wrong.
i am having the same problem. but i have a pioneer FB90. when it was in my 2010 Silverado it was great and it didnt have the bose. now with the Tahoe and Bose i have to increase the sound 10%
the little white thing is a gain adjustment.. it is used to match the output level of the deck to the input of the interface. for general setting you can turn it all the way down, turn deck vol to 3/4(if vol goes to 40, set to 30). then turn the gain adjustment till you hear music go into distortion. then back it off just a hair.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
