speaker sound bad after kenwood install
bloodynj
I have 2011 tahoe with bose sound system. I loved the sound before installing my dnx6990 with gmos 100 adapter. I tried playing with the settings of the audio but it still sound bad. Any tips
Modded
That Guy
What sounds bad about them so we can help better?
B
bloodynj
No bass at all no matter how high I put the bass on. I also enabled the sub woofer to see if that helps. but it doesnt. also the sound itself sounds ok at low volume but at high volume it sounds really really bad. like I cant understand the words being said and still very low bass.
my stock setup used to make my mirrors shake.
Modded
That Guy
Your high pass filter may be on too high.
Look for the high pass setting and set it to between 60hz and 80hz.
I have a non-Bose system like you with Pioneer door speakers, a separate amp and sub, and a Pioneer head unit.
It sounds far better than stock even with the sub off.
Modded
That Guy
I made a mistake and just realized it.
I meant your low pass filter should be in that range if it has a setting that adjust the low pass for the door speakers.
groundscr8pr
flaccid member
scarborough maine
all hp/lp filters should be set to off/through. the bose amp does all of thison its own. you need to send a fullrange signal from the head unit to the bose amp.
B
bloodynj
well I found the problem. its in the GMOS100. I had to turn that white thing with the screw to increase volume. I dont know how that effected it but it sounds way better now.
so I should set everything as through?
Btw how do I know if the amp is working. because I have a feeling I got the wiring wrong.
aflumb
Las Vegas
i am having the same problem. but i have a pioneer FB90. when it was in my 2010 Silverado it was great and it didnt have the bose. now with the Tahoe and Bose i have to increase the sound 10%
groundscr8pr
flaccid member
scarborough maine
the little white thing is a gain adjustment.. it is used to match the output level of the deck to the input of the interface. for general setting you can turn it all the way down, turn deck vol to 3/4(if vol goes to 40, set to 30). then turn the gain adjustment till you hear music go into distortion. then back it off just a hair.
Merch619
