Spare rim with belltech spindles
Shortstock
Life is good today!
Prairieville Louisiana
Ok when using 2 in. Spindles that require17in. Or bigger what spares are y'all using. I'm on 26s .would love 22in Chevy transit wheel but hard to get and costly. A cheap 18in. Steel wheel would work . I want 18in. Or bigger so I don't have to modify my spindles or balljoints . What are y'all using .
bottomline2000
Dallas, TX
Interested in options due to gmt900 upgrade..
Sent from my SAMSUNG-SM-T377A using Tapatalk
Shortstock
Shortstock
Life is good today!
I can't find just a cheap steel 18" rim for nothing .plenty of 17"s. If I catch a flat on front ima have to take a wheel from rear put it on front and put spare on rear . Double work right .
Not sure if there is an 18" steelie. Get a standard 17" spare steel wheel or an alloy 18" if you insist on having an 18". I see 18" OEM take-offs (usually from 4WD) all the time on CL.
Shortstock
Shortstock
Life is good today!
I would love to just use a 17" but then you have to grind down almost all threads on bottom balljoint then use a special nut that is barely 1/4" thick. Don't like that idea . I probably just get a 20in" stocker off craigslist or something .
Bombsquad85
Northern VA
In all honesty I was thinking about this and it only affects the front of you get a flat in the front just throw a rear tire up front and the spare on the rear
bottomline2000
Dallas, TX
Thats a lot of work. What size spare do the newer trucks with stock 22s have?
HiHoeSilver
Away!
Chicago
Just like the Gmt900 brake upgrade. 17" minimum. If you get a flat, you gotta swap front and rear. It ain't that bad.
bottomline2000
Dallas, TX
Yeah I get that. I have the gmt900 upgrade is the reason I ask. What do the trucks with 22s have for a spare? I know it's got to be a taller tire. Even my 20s are short compared to my 24s. What's a 17 gonna look like?
Shortstock
Shortstock
Life is good today!
Yea I can jus go bigger on the tire till it's tall as my 295/30r26 that's no issue. Looks either . Just don't wanna have to modify my spindles or balljoint. They say 17in or larger work but really it's 18in or up without modifications. I have a 17in spare and it drags the balljoint bolt.
briannorris
