TahoeRestore
- Joined
- Dec 9, 2021
- Posts
- 62
- Reaction score
- 106
2003 Tahoe 170K mi, 5.3L. 4WD. I've been trying to fix an oil leak and am looking for advice on the next step. I have replaced the Oil Pan gasket and the Oil cooler line blanking flange (pic). I cleaned up the surfaces nicely, used RTV at the corners, hopefully aligned the oil pan with the back plate, and replaced the oil pickup tube o-ring. I can't see any oil around the oil pan gasket area, but getting oil drops appearing on the inside mounting bolt for the starter (pic) and a little on the left rear pan long bolt (pic).
I've looked up top with an inspection camera around the Cam Position Sensor and Oil Pressure sensor which I replaced a year ago (pics). I see oily grime up there. It hard to clean and see if it gets wet again. I can't see any sign of a leak around the valve cover gaskets but will probably be replacing those soon anyway since it's not that hard of a job. I would get the new design cover.
I'm concerned it may be the Rear Main Seal or rear engine cover gasket. It looks pretty clean on the fly wheel and inside the bell housing (inspection cam pics).
I've noticed that it continues to leak even when it hasn't been running. It's been sitting for three days and still leaking (floor pic). Isn't the oil level in the pan lower that the gasket at the top of the pan? The front of the truck is on stands so maybe the oil level in the rear of the pan is above the pan's top?
If it's the RMS or rear plate gasket, I'm going to have it fixed by a shop and get a transmission rebuild while it's off. The transmission and engine have no issues so hopefully if it's not leaking there.
Like a lot of you, this truck is my baby and I've been keeping it up and improving it for years. Ideas are greatly appreciated.
Thanks!
Thanks!
