SOLVED: Another misfire chasing threads (2008 express van)
Tonyv__
Tonyv__
Bucks county PA
You want the cat to show close to the same temp at front middle and back.
So driver side is reading like 350ish front/middle then over 500 at the back of the cat right where it welds into the exhaust pipe. I would think a blockage would be hotter in the front. But what do I know
Passenger side is a little more consistent like 400ish through the whole cat.
I'd say it's a little clogged. Hollow that beyotch.
Multnomah Falls
You have a problem with drivers side cat. If I was doing it, both would be replaced but is your call and unless sensors are relatively new, I would do all sensors, too.
Tonyv__
Tonyv__
Bucks county PA
That is what caused it. You repair it as you see fit.
My tester is showing 8-11 psi back pressure at the 02 sensor closest to engine when revving engine. Definitely some restriction
It’s actually showing 0.06 - 0.08 MPA but that converts to 8-11 psi
Tonyv__
Tonyv__
Bucks county PA
So I got around to “fixing” the exhaust. I intended on getting to both sides tonight but I was only able to attack the driver side. I’m about 4 1/2 hours into this project. The bolts on the exhaust flange were so rusty that of course I broke 2 and had to grind off the 3rd… getting the studs out of the manifold was another nightmare. Had to run to Home Depot and get the most expensive drill bits they had just to drill out the studs.
I will say though. She’s running like a r*ped ape now with no restrictions
Tonyv__
Tonyv__
Bucks county PA
@Tonyrodz does your van sound a lot louder after you removed the cat?
I assumed it was a leak then I went under tonight finished the rear clamp and double checked everything. I got a throaty exhaust now lol. I don’t hate it but in a van it just sounds broken not so rowdy like a truck would
A little. Cats kind of act like mufflers. When I gutted the cat on my 01 it sounded really throaty, nice growl when you romped on it. Race van lol.
Jake 2015 GMC Yuk
