smells like its getting to hot
jdawg901
memphis tn.
i replaced thermastat with the correct temp 195, fan clutch ,coolant temp,havent changed radiator or pump.is it possible for the pump to go bad without the leaks.also shouldnt there be some type of recirculation motion in the radiator .when i stop and cut the truck off it has that overheating smell and a hissing noise from the front of the truck.
haks310
Got LEDs?
SoCal
Is it over heating or does it just smell like it? Also did you try testing the thermostat before you dropped it in?
blueflamed03
Oklahoma
sounds like water pump is out.
Cheap investment, add a new one anyway, it's not like it 'couldn't' use it anyway I'm sure....but sounds like it's bad.
briannorris
