Slight rubbing
06xl
MD
I just threw on a new set of 22's with 305/45/22 tire an I'm rubbing alittle when I turn tire to the left any idea why???
oakrdrs187
Coachella,CA
I blame it on having tires too wide.
you should be running 285/45/22.
Rule of thumb up ten down ten.
Start at 275/55/20
stock 20 in. Size.
+10/-10
285/45/22
295/35/24
305/25 or 30/26
otherwise you mess up your speedo readings
brassknucklemafia
phoenix
:)try 315/30/24's they rub turning both ways. :) now all i rub on is that damn little bump on the drivers side of the firewall :emotions122: rubbed everything else off, and according to GPS im only off 2mph on the speedo
06xl
06xl
MD
I'm rubbing when I turn the wheel to the left It only rubbs on the driver side
brassknucklemafia
phoenix
theres a couple of places on the drivers side you could be rubbing on when turning left. one could be the lower part of the wheel housing cover that covers the windshield washer bottle, the other could be the same little bumps on the firewall that i rub or also the far inside of the wheel housing liner behind the tire near the firewall. best way to tell is to take a flashlight and look for marks indicating where you may be rubbing. you may have to trim, so as to not rub. as in my case i have to live with it or run a more narrow footprint of a tire.
Da90
Tulsa, OK
I'm running 305/45/22 on my NBS. It only rubs at full steering lock. It's not bad enough to worry about. Nor does it tear up tires. I wanted the biggest tire I could fit cause of ride and look. If you are worried about them rubbing should have bought 285s like stated above. IMO just leave them for the wide stance! If your speedo is off buy a cheap programmer or get a blackbear tune!
06xl
06xl
MD
Thanks fellas i found out were it's rubbing so I just shaved off alittle peace of plastic an I'm good to go it was a section that covers the washer fluid bottle
06xl
06xl
MD
@brass yes it was right were you said lol
lv05denali
Las Vegas, NV
did you lower your ride by any chance??? i ask because, i think the 305/45/22 will have the best "fill-in" look without having to drop the denali. however oakrdrs187 mentioned 285/45/22. i've never seen 22" rims with the 285/45 tires. just wondering how does it look. or i could go for the proven size of 305/40/22.
06xl
06xl
MD
@lv05denali no I didn't lower my Denali stock Height front an back an the 305/45/22 fill in the gap fine
briannorris
