Shopping for a 2015+ tahoe or yukon
tim crow
I like the look of the Yukon better but would really like the z71 package, is there a equivalent for the Yukon? how hard are these to do custom tuning on? is there certain years that are easier than others? I would also like the 6.2l but would rather have the 6 speed over the 8 or 10 speed..
T
tim crow
im also considering buying a 2nd gen Tahoe. z71's seem more plentiful and reading through a couple post on here the quality of new ones are questionable
Bob2C
Northern VA
Tunes are easy. There are a few tuners mentioned here but the big ones are BlackBear and Diablew. I had my 18 5.3 done by Diablew. Wow. Big difference in drive ability.
sealandsky
Minneapolis, MN
I'd aim for a 2018 Tahoe or Yukon with the 6.2 and the 10 speed transmission. The 10 speed tranny is very good and the 2018 model is easier to tune than the 2019 onward due to ECM security measures put in place by GM.
sickk23
New Mexico
No there's not a Z71 equivalent for the Yukon.
The 10 speed is the best hands down. Denali or RST (w/optional 6.2) would be the way to go IMO.
T
tim crow
I like the sound of an early 15 denali with the 6.2l and 6 speed. Ive read the early ones have a lot of issues but hopefully all the issues have been worked out by now. Or are they that bad?
Sent from my SM-G973U using Tapatalk
sickk23
New Mexico
Haha I wouldn't touch an early 15 with a 10 ft pole. I wouldn't say all of the issues have been worked out, I think GM just gave up and started over. The 2018 + are a lot less problematic and like I said the 10 speed is the best.
avalonandl
Troy, MICH & Naples, FL
I don't think the early 15's are bad. Any used vehicle I WOULD drive extensively to check it out. I like the 6 speed auto better than the 8 speed....
91RS
GA
You couldn’t give me a 15 or a 16. I’d skip the 17 just because of the 8 speed even though the 17 does ride a whole lot better. Honestly, I’ll very likely be skipping owning one of this body style altogether BUT if I was forced to own one it would definitely be at least an 18 with the 10 speed. Hopefully my 08 and 12 last a long time to come.
sickk23
New Mexico
An early 15 (or any 15) is way more prone to rough ride/suspension annoyances, booming/buffeting, unsolvable vibrations and build quality issues. Besides that, they're 5 to 6 years old now so there's probably more issues about to pop up. There were complaints with the early 6 speed and still with the 6 in the 5.3s, the 8 speed was obviously junk but the 10 is near amazing. But like you said, an extensive test drive would weed out those issues most likely. And I mean someone has to buy them.
JML07denali
The 10 speed is not that amazing as you may think. I had a 10speed in my 19 6.2 Silverado LTZ (just got rid of truck). I had tranny issues from the start let alone I had at least 12 recalls, fuel management issues, leaking rear windows, etc etc. Talking to my service advisor GM is having a ton of issues with the 10speed tranny as well.
In regards to Tahoe or Yukon. I think your best bet is to test drive a few of them and see what you like. I was lucky enough to find a very clean 16 Yukon SLT for my wife this past Jan. So far she has had no complaints. 6spd tranny runs great with no issue to report.
sabasigh
I just came from a 2019 Ford Ranger w/10sp. Thought it was a wonder @ first but about 3k miles it just started getting harsher & harsher. Everytime i see some public article/post ragging on the Ford 10sp, i always wondered "well GM is using the same thing and is their implementatino that much better?"
My 2020 Yukon only has 220 miles and so far i barely notice it. We'll see after i get a few thousand miles on it.
Dre013
The problem with my ‘15 hasn’t been the drive, it’s been the electronics and sensors. Just a mess to the point they gave me an extended warranty.
Miami-Dade
Moderator Supporting Member
Reading through a couple post on here the quality of new ones are questionable
When it come to early 2015's it is a hit and miss. Some members on here had no issues and others had a ton of issues. Some to the point of lemon buyback. Make sure you get ALL SERVICE RECORDS and have a good independent mechanic check it out from top to bottom on the rack just to be sure. Just IMHO.
I bought my 2016 5.3 Tahoe LT with the 6 speed new in August of 2016. So far [with the exception of a A/C Condenser] it has been nothing but plain old regular service. Knock on wood. Just had my Tahoe serviced last week [85K miles] at the GMC dealer and the service advisor said just keep on truckin. No upselling of any wallet flushing services.
If you do decide to get a 2015-2017 just know your a/c Condenser will probably go belly up if it is has the original Condenser as it is a known issue. Mine went out 80K miles but others here had them go out much earlier.
Kimble09
First post here, hello everyone!
I was torn between the 3rd gen and 4th gen Denali...but im seeing lots of concerns with the 2015's. I still really like the looks of the 3rd gen...would a 2104 Denali be preferred to a 2015?
I'm looking at 3rd gens under 100k miles. I can get them so much cheaper than the 2015+...any advice would be appreciated!
Cheers!
91RS
GA
If 14 and 15 were the only options, absolutely the 14. The newer body style does look better than the bug eyed 14 but the 14s just feel more well built and they ride a whole lot better even with 22”s.
BourbonNcigars
As much as '15's scare me based on what I've read on this site, I could never bring myself to buy a '14 with the previous body style just because....the body style changed a year later (a style which looks, in my opinion, much better). I'd rather risk the quality issues than have an the older style just for cool factor and resale possibilities. Just IMO.
If I had my way I'd order a brand new 2002 - 2006 model but I don't think that's an option. ;)
T
tim crow
I ended up getting a 17 tahoe LT with the max trailer package and pepper dust metallic paint. I have a diablo sport I3 that kept from my ram i traded in. If i have it unlocked for the new truck can i use it on the tahoe with a tuner like blackbear?
Miami-Dade
No need to be scared of the 2015+Tahoe-Yukon. I talk to owners all time at gas stations and rest areas when I drive up in NYC. Not one had a complaint. A few of the ones I spoke to said they were rentals and loved them so much they said they planned on buying one for their next vehicle.
If you get ALL SERVICE RECORDS plus take it on a nice long run on both highway and surface streets plus have a good independent mechanic check it out from top to bottom you should be good to go.
Glad you jumped up to 17 LT. Hopefully you have all service records.
You might want to ask your question about the diablo sport 13 in the Performance Section.
Durobans
