Shocks X4
Samuraj
Des plaines
for sure my hoe needs better shocks , I know bilstein make one for rear, how about front ?
How about different brand ?
Like to stay in same height
domoarigato
Height isnt determined by shocks, the springs do. As long as the travel distance of the shocks is the same as factory you can go with any brand.
Samuraj
Samuraj
Des plaines
Any recommendations?
PPV level , and possible stock 20" wheels
Originally I was planning on 17" wheels , but .... not sure anymore o_O
Samuraj
Samuraj
Des plaines
Confused..
20765171 / Strut, RIGHT
2WD, DELCO# 540-460
$88.44 20765171 / Strut, LEFT
2WD, DELCO# 540-460
$88.44 19300066 / Strut, LEFT
2WD, DELCO# 580-364
$261.68 19300066 / Strut, RIGHT
2WD, DELCO# 580-364
Samuraj
Samuraj
Des plaines
Maybe better view
domoarigato
I believe the DELCO# 540-460 is for non-autoride tahoes (which ppv's are I believe). Autoride was only found in LTZ's. Dont quote me, but it makes sense as to why the other struts are so expensive.
Samuraj
Samuraj
Des plaines
I'm calling police ‼️
Fleet maintenance department where my Tahoe was serviced , maybe they know ....❓
Samuraj
Samuraj
Des plaines
I found the struts , shocks ... on my own , so you guys can go and .....:mad:
Ask me how I did it ;)
adventurenali92
Big Bear Lake, ca
Those part numbers starting with 193 are the auto ride shocks I believe. I could be wrong but I just ordered new shocks for my 2006 Denali and the auto ride part numbers started with 193 as well. You should be looking for the 207 designations.
Samuraj
Samuraj
Des plaines
20765177 front
25871234 rear
Stock height ..... no info about Police package , my dealers , has no clue ...
THEGREG
I'd suggest searching Rockauto.com They will show which package applies to which strut.... and if your asking, yes, Struts up front (spring over strut), and shock in the rear (independent shock w/ leaf springs).
As far as your sore butt.... its the spring/shackle set up on the PPV trucks, they aren't soft, they are meant for handling.
This is for rear shocks...
AC Delco is 540297 (long # 15935565) $58.79 each
or
KYB "performance'' 565125 for $74.79
http://www.rockauto.com/en/catalog/....3l+v8,2002727,suspension,shock+absorber,7556
For front Struts (I believe the PPV is suspension code is ZW7?)
KYB ''GR2'' 34149 $79.79
KYB "Gas-A-Just" 551121 $84.89
KYB "MonoMax" 564004 $92.99
http://www.rockauto.com/en/catalog/chevrolet,2010,tahoe,5.3l+v8,2002727,suspension,strut,7584
This was the only thing I could find when crossing the factory GM number for the front struts...
which is 20765177
ACDELCO 54050 $113.79
http://www.rockauto.com/en/partsearch/?parttype=7584&partnum=20765177
992dr
Eastern N.C.
Going to gmparts with vin will get you exact replacements but, you have to use your vin. Get part numbers and go from there.
I got Bell Techs adjustable struts. For two reasons 1.) firm ride 2.) to lower it
Our Tahoe's don't have shackles. We have parallel 4 link with pan hard bars and coil springs.
To relieve yourself from sore butt syndrome, start with the free travel mod.
Samuraj
Samuraj
Des plaines
Cannot really say, my old ones are garbage , truck was riding all over the road ..
rossida
