Service Stability Control and ABS / Traction Control warning lights 2004 Yukon Denali
YukonXL2
DIC message noting service stability control. Then couple of weeks later and out of nowhere chimes going off and ABS and traction control warning lights. Then very sporadically I get very diminished power although this clears quickly. Power issue is really prevalent in stop / go driving but not on highway with cruise set. Also shutting engine off (generally) does not clear messages or reset warning lights. Anyone had this or similar issues? Thanks.
Sam Harris
Texas
It’s most likely a wheel speed sensor. These get corroded / covered in gunk, and sometimes just fail. When the system detects a differentiation in wheel speed (as in not making a good connection), the ABS / Stabilitrak is activated. You’re probably looking at either a sensor, or wheel bearing / hub replacement. Sometimes they can be cleaned up. Definitely need to get the wheels off the ground, and check for any play, pulling / pushing the wheel at 12 & 6 o’clock, to check for any play.
GMT800 2005 Tahoe Z71
Navy Supporting Member
What @Sam Harris said. Many threads here about the same symptoms. If you do find a failed sensor or hub, do yourself a favor and do both with quality parts.
Congrats on your first post as a member.
nonickatall
Germany
Was exactly my problem. It started with error messagings of the traction control and later on came noices from the wheel beering hub. The ABS Sensor witch is also necessary for the traction control is included in the wheel bearing hub.
If you do it yourself, you need half an hour for each side, if no rusted screws or else....
When your order the wheel bearing hub be careful. There's one version for cars with AWD and a version for cars with 2WD.
Make sure you check for any damage at the wires to the sensor. If had recent work done in that area, may be wires problem and if just start throwing parts at it, you will still have a problem.
Welcome to the Forum from NH.
Pics of the truck, please.
Fomoodie
Did you fix your Traction Active issue? I’ve fixed six Yukons with this issue. The ABS module under driver's side have solder joints that fail. There are videos on the repair on YouTube…
Marty_S
Also one for 4x4 according to Autozone(?).
brice715
