Service Instrument Cluster @634 Miles, 2022 Yukon XL Denali
WalleyeMikeIII
WalleyeMikeIII
Sunny and Snowy Minnesota
Hi guys an update: i picked up my Yukon from dealership today - they said they have a call in to GM tech support because they could't see anything wrong . They checked for software updates and said that GM currently doesn't have any but they did do an update on my radio and display because there was one for that. They said this was "new" to them as they haven't seen anyone with same issue. I did tell them after about yours WalleyMike having same issue and what your dealership said. They will let me know next week what the tech support says - so unfortunately nothing at this point....
That’s ok, thanks for the update. If you hear any more, keep us informed. I’d be curious what update they applied. Hopefully if enough of us bring the issue to our dealer, they will figure it out.
Toasty
The PIT number you reference calls out "This preliminary information communicates an issues with false codes setting in vehicles due to timing issues between the modules" -so at least one of the connected modules isn't seeing or providing communications in the expected time.
WalleyeMikeIII
WalleyeMikeIII
Right, or at least in the time the “software” expects…when they talked to me, they implied GM was aware of the issue, and that it was “algorithmic.” Those pieces of data imply it’s a software issue. Hasn’t occurred for me again since they cleared the codes.
Patsy
I will make sure to post what dealership hears back from tech support just very frustrating paying this kind of money and having issues already -
jszerelmey
I had this message come up this past Sunday. Had a scheduled apt at the dealer to address a noise coming from under my XL and brought this up. GM actually released a bulletin on this issues yesterday. No fix as of yet but apparently they are taking steps to fix it. Tech said most likely a software update
WalleyeMikeIII
WalleyeMikeIII
Any chance they gave you the bulletin number?
olyelr
Elk Rapids, MI
Started her tahoe up early morning to start off our 18 hr. trip to florida for spring break….dash was completely black. Nothing. No speed, no idea how much gas we had. Nothing. Just black. I think it did say something about service instrument cluster for a second, then just went all black.
Swung into auto parts store and bought a 10mm. Unhooked negative battery cable, waited a minute, reconnected and all has been well ever since.
These things should come standard with a 10mm wrench in the glovebox. Between this and the issue with it not starting after a remote start…I sure as hell will keep one in there from now on.
WalleyeMikeIII
WalleyeMikeIII
Gotta love it…give it the ole Windows “reboot.” Argh,
WalleyeMikeIII
WalleyeMikeIII
Hey all, just thought I’d check in. I’m now at 2400 on the odometer, been error free since dealer cleared the codes…starting to think maybe this was some stuff left over from the manufacturing process or something.
kcb14214
This happens in my work Tahoe every couple weeks, but hasn’t happened in wife’s Yukon yet.
Genlarkin
My issue started at less than 100 miles on my 2022 Yukon. The instrument panel goes black, only way to get it back is to turn car off and back on. I've had the yukon a month and it's happened 4 times. Goes into dealer next week.
olyelr
Elk Rapids, MI
My issue started at less than 100 miles on my 2022 Yukon. The instrument panel goes black, only way to get it back is to turn car off and back on. I've had the yukon a month and it's happened 4 times. Goes into dealer next week. View attachment 369242
That happened to my wifes high country. Only thing that got it back up and running was disconnecting the battery. Frustrating!
suburbansince87
Wife’s 22 Denali is now doing this, this thread was the first search result LOL.
“Service instrument cluster” with 3000 miles.
It doesn’t sound like there’s a point to taking it to the dealer right now? No TSBs or anything?
Should I just disconnect the battery cable?
WalleyeMikeIII
WalleyeMikeIII
If all it is doing is sending the message up, just dismiss it, it basically goes away.
There is a preliminary info document (PIT5901) ...but last time I read it, it just said engineering was working on it.
Just verified here https://static.nhtsa.gov/odi/tsbs/2022/MC-10210340-9999.pdf still seems to be "working on it"
Donna
Pic worth 1000 words, going to dealer tomorrow, doesn't bode well. Will post back w/ the diagnosis from the dealer. Was hoping to not get to know their service guys too well :(
I’m having issues too with my 2022 tahoe I jus brought brand new.. they’re going to replace my instrument cluster today.. hopefully that resolves the problem. What did the dealer do for yours?
WalleyeMikeIII
WalleyeMikeIII
The whole saga is in this thread…net it’s a software issue GM knows about. Relevant TSB’s are linked.
Escalade2007
