SEO 6j4 explanation?
Canadrian
Hello I found the wiring for horn/siren provision but I'm confused as to how this works? Can someone explain it to me please? I have a whelen siren but it usually hooks up to the code 3 control box does this SEO 6j4 mean that I have hit the horn pad and use this siren instead? That doesn't make sense as the code 3 controller has to select the sound coming out of the siren... Does this make any sense??
bobo49505
there is not a siren there. 6j4 just means the wiring is there running thru the firewall to hook up to on both sides
Canadrian
Canadrian
Oh sorry I know there's no siren there but I have a 100w whelen with a code 3 controller so I was just wondering how hooking up a siren to this provision would work? Just by pressing the horn button pad I'm confused how a siren would work as I thought it needs a controller to put out the sound.
bobo49505
here is what the manual says
6J4 WIRING - HORN/SIREN CIRCUIT
Two 16 gauge wires are connected to an in-line connector in the horn
circuit of the instrument panel harness under the instrument panel. The
end of this harness extension is terminated with an in-line connector in a
60 inch coil under the instrument panel. Connection to customer switching
permits operation of the horn or siren with the horn button.
you hook the wires up to your controller and can change tones with the horn button instead of the control panel
Drewphil
