sensor or vac line
jdawg901
memphis tn.
can anyone tell me if there is a vac line or sensor that goes to the trans .i asking because i changed out my fan clutch and now im gettin a big fan sound like the truck is straining from 1st to 2nd then to 3rd after that alls well until i come to a complete stop then have to go thru it again .it usually revs to about 3000 rpm in 1st before it shifts same with 2nd it almost sounds like a big rig drivin off.oh and it dosent seem to have the pull until i hit 3rd gear
qlc1964
qlc1964
you have a new fan clutch and it will sound like that until it warms up or if you run
the ac. now if it still does it after 30 min of driving then it could be something else.
have you changed the trans filter & fluid?
jdawg901
jdawg901
memphis tn.
no it use to do it when i ran the ac but now it does all the time since the new fan clutch .its not loud when first start up just the regular warm up phase
jdawg901
jdawg901
memphis tn.
torqflo/fan clutch note: heavyduty thermal value offering lighter duty than o.e thats what it said on az site.after lookin maybe i should have got the premium xtrem duty for suv light trucks and motor homes that operate at an higher rpm .since it being a lighter duty could be workin a little harder than the oe part.im sorry guys for all the questions but i really want to get the truck back up to par before winter .i live in memphis so we get really ****** summers and even worse winters no snow just rain and ice
haks310
Got LEDs?
SoCal
It is a 4x4 right? Try going to Kragen if possible and getting a Hayden fan clutch, the heavy duty one. I will dig up the part number for you tomorrow.
jdawg901
jdawg901
memphis tn.
no need ,i really appreciate it i went ahead and took it back for the haevy duty one theres a diff in the thickness the new one is about 1.5" thicker than the light duty .put it on a no big fan and better shift thanks haks .i have another problem now but not as serious will post that on
ravingmadman
Chief Knuckle Buster
Greater Seattle
Yeah, I'm 99% sure your fan clutch and shift problems are separate problems. The systems don't touch each other, and aren't close to each either, unless something obvious happened, like your fan ate your cooling lines, but that would be pretty obvious. :)
ChiefTW
