Second battery
Samuraj
Des plaines
specific on PPV
Which power cable is not in use ?
So I can run to the second battery
PG01
Up here to the right
When i did my dual install I bought everything from amazon but it was all gm parts and i did it in parallel. Mine is a 13 lt hoe and i looked at the 13 ppv to see how they did it. There were so many diff setups though, ppv ssv ya know. Now if I remember correctly one of those leads goes right into the fuse box right under hood and the other ones were for police equipment inside. My year ppv parallel setup had a positive cable running from first battery(pass rear engine compt) to starter and second battery(drivers front) positive along front of motor to starter and then neg to side of alt. I think the one that goes inside is ur best bet. Not sure if i helped you but thats my best guess. Maybe look at starter to see if a second batt cable is connected there and just left by the second battery u put in. Sorry bud.
S
Samuraj
Des plaines
I have 3 red cables , 1 goes to fuse box , 2 inside the cab
I'm talking driver side ...
992dr
N.C.
I would leave the factory wiring in place. I would just add another cable to the positive terminals , and a ground wire to the frame.
Messing with the factory wires is when good things go bad. But, I'm no electrician either.
I ended up getting a complete kit.
S
Samuraj
Des plaines
I think I have schematic ...
Any way , I will run extra lead and leave factory set up , I need to check how they disconnect all this equipment...
A ha , PPV / SSV section will nice ...
badandyturbo
Florida
I have the factory dual battery setup but I can look around if you like to see if I see anything special.
davidl13
Make sure to tie the grounds together.. you don't want a grounding differential.. things can get ugly
BWASTEEZE
