Scanner Recommendations
Tuscan Ranch
I already have a code reader (Innova 3020) but would like to upgrade to something more advanced with two-way functionality. Suggestion are welcomed.
Also, does the 2007 Tahoe Z71 use the GMLAN protocol or ODB2?
Thanks!
Thanks!
GMLAN, we use a Tech2 with the CanDi to talk to all the modules and interact with them.
Someone mentioned this one the other day but don't know anyone that's bought one yet:
Still love my Tech-2 for working on these GMT900s!
Charlie207
LFOD, New Hampshire
Foggy
KS
You can get an AUTEL brand of scanners/bi directional starting at about
$700 depending on what features you want. They have a "store" on amazon
with good/ helpful info
T
Tuscan Ranch
For those not in the know, often auto manufacturers will extend exiting protocol like ISO 9141, J1850 PWM, Keyword 2000, CAN, and VPW.
Tech2 is a hand scanner based on GMLAN which is a set of high level protocols for diagnosing ECU systems on supported vehicles. There are more than 20 different commands for reading,writing, and clearing information inside an ECU. GMLAN is a combination of GM2190 and Keyword 2000 diagnostics. All functions are defined in GMW 3110. GMLAN uses functions from ISO15765-2 (USDT Messaging) and supports OBD CAN, legislated by J1979 Requirement.
GMLAN has been extended with additional requirements and is often referred to as GM Global A. Global A includes many types of networks and protocols.
As for tools/scanner, Innova is the largest American company for these type of tools. Top line models with Full feature set are 5160, 5160RS (new model), and 7111 (tablet). I've seen them 2nd hand for $150 to $400.
I looked at Launch brand (linked above) but wanted something HQ here.
If you liked this post, please give it a big thumbs up!
j91z28d1
is this the new way spam works? you ask a commonly asked question, wait for a few replies and then paste an ad for your products?
bots are getting good enough to be properly annoying.
to anyone else that see this thread. I've used a ton of different scanner over the years and unless you need to flash software updates to different modules in your truck, just buy a clone tech 2. it's the best 275$ you'll ever spend if you have any desire to fix things yourself, or understand what's being fixed on your truck. everything else that's any good will be 3 times that and do less. I've got a 2500$ work scanner that while it will work on a wide range of manufacturers, it doesn't do as much as a under 300$ tech 2 does.
just buy it.
T
Tuscan Ranch
just buy it.
Bad day? That’s ok we all have them. Even us bots. At least our language skillls have improved to fool the bags of water.
When I posted the only thing that I knew about OBD was that it’s a computer interface for diagnostics.
The link led me to Amazon which was a waste due to the lack of quality information and filled with overseas crap.
My intent Brandon was just to share what I learned. Sorry I offended you.
Peace
the tech2 is a J2534 Compatible device, so is the MDI, MDI ii, vcx-nano and others, the tech2 can be connected to the vehicle and to a computer to act as a pass thru device to load calibrations to modules in the vehicle. for instance if you replace various modules they will not work unless they are learned to the vin of the vehicle. you can use "used" or "new" modules either way certain modules require a re-learn to the vehicle vin, some can be done with just the tech2 standalone and some require a more advanced procedure using gm software online (for a fee)
J2534 is a standard used by all manufactures
j91z28d1
Peace
you knew nothing about scanners yesterday at 10pm and learned all about the standards at which they communicate on by 2pm today, also finding the best one with a HQ huh.
let me guess, you're product has a "HQ" in the states but it's built in the same place all those other cheap Amazon scanners are built? along with all the other electronics in your house and the phone in your pocket.
Coolman1987us
Maine
I have the VCX_Nano as well - works fine once you get through the setup frustrations! I have used both setups on my SSV with success.
I read a lot about the problems people had. I experienced none. I installed everything from the USB stick that came with the nano, in the correct order, and it worked flawlessly on both win 7 and 10. I think most issues are with the driver install, which is where the order you install the software matters.
security needs to be turned off and whatever it is installed on should be in desktop mode, the software is hacked so it changes some windows files to make it work, if security picks up on it then it removes the necessary files to make it work. even doing a windows update can break it. And the vcx software needs to be updated from time to time to keep the license working which includes updating the firmware on the nano. I have had mine for 3-4 years now lately it seems they have corrected some issue's that were a problem before so if yours is more recent that may be why it went smooth. In the past it has been a struggle to make it work.
using the gm techline software is another mess if you ever need to load some calibrations plan on some time to load all there crud before you can even begin
XSGforce
I have a CGSULIT, basically a Tech 2 clone I think. I've used it a few times and it's done everything I needed it to. It does basic OBD-II for other brands but has the full bidirectional function for GM or whatever brand you order it for. It does seem to be slower than my mechanic friends Tech 2 but it's been fine for me. Around $150.00 typically. The first thig I did was check for alcohol content which showed 70% in my 2007 Yukon that's never had E85 in it. I reset that and the long term fuel trims and it cured it from being hard to start and idling rough while blowing black smoke for a few seconds after first starting. I used it for a couple of other things and with over 300,000 miles I'm sure I'll be using it again eventually. The Innova scan tool I had previously showed codes for bank one and two rich condition and bank 2 sensor 2 which turned out to be chewed wires. Once those issues were fixed the Innova showed no codes and the check engine light stayed off. The CGSULIT found 17 codes still stored. Most of those were issues that had already been repaired over the years but it also pointed me in the right direction to get my cruise control working again.
just thought I would post a update regarding using a vcx nano, I had not used mine for a minute and being a new year now these devices have to have regular updates to function
spent quit a bit of time getting it to work (again) with current updates and got gds2 up and running and the vcxdiag showed up as a interface but would not read the VIN!!!
so after a bit more time of screwing around discovered techline software needs to be installed, doing this apparently installs a j2534 wrapper driver which is needed for it to communicate. Atleast that's my synopsis thus far, once the techline software was installed everything worked again. even though I am not using techline and just using GDS2
I guess I am good until the next update.............:angry94:
The Whip
