Rusted out & Leaking Brake lines - Brake line Diagram
Bxcliff
New York
My front brake lines started to leak fluid on my 2003 GMC Yukon Denali and i'm fixing to replace the leaking ones for now and replace all the other rusted out lines after winter ( I live in Upstate NY)
I tried searching for a diagram for the brake lines from the abs and the rear proportioning valve so i know which lines to replace for now but couldn't find anything online, don't want to cut out the wrong ones.
Also, any tips i should know going into this job? Any help is appreciated, trying to get my truck up and running to commute to and from school when it starts to snow.
Thanks
Bxcliff
Bxcliff
New York
I've seen that picture, but the one on my truck has 4 lines on top and 2 lines under it, not too sure if it's the same, what do you think?
And the whole kit isn't that much expensive so I'll order it as soon as I can thanks man
Sent from my SAMSUNG-SM-J727AZ using Tapatalk
Z28TWITCH
4 on top? I have never seen one with 4 on top. Always just 3 up top and 2 on the bottom. Got a pic?
Bxcliff
Bxcliff
New York
Yeah I can take a pic later after school this morning
HiHoeSilver
Away!
Chicago
I think that's because of RPO JL4. "Active brakes" enhanced stability system. 6 lines instead of 5.
OneofFew
Talullah Falls, Ga
Screw the kit. just get a roll of easybent line and dont even bother trying to run them like oem.
search this forum for some write ups.
Bxcliff
Bxcliff
New York
So if my front driver side brake line is leaking would I still go by that same diagram with 5 lines?
Like I said I just want to fix the leak for now and replace the others after winter
Off Road Pedia
