Rear Wiper Washer Not Working
YukonCrazy
Raleigh, NC
So what is the most common cause of the rear window wiper washer not working? Front washers work fine.
HUMBL57
AC Guru
Phoenix, AZ
I'm also interested to know. Mine doesn't work either. It's not important enough here for me to wait half a day at the dealer for warranty repair though
byrds6
FL
A lot of times the tubing comes out from a connection front to back. Push the button and see if water pours out underneath. Mine was that at one point til it quit again and I havent found out why the second time lol.
JML07denali
Agree on this method, if you don't see any leaks then the pump that sends water to the back is bad. Two pumps are attached and located under the windshield washer tank (one for the front windshield the other for the rear window) the washer tank is located under the battery.
byrds6
FL
There also can be a clog in the last stretch of tubing to the out on the blade itself. This is what I believe to be wrong with mine as I can disconnect the tube in the rear quarter and get it to pump out. However it will not get water out of the blade itself.
GM Customer Service
Michigan
Hey YukonCrazy,
I’m so sorry to hear that your rear window wiper isn't working. Unfortunately, I’m unable to provide technical advice, but if you’d like I can certainly look into your concern further. If my help is needed feel free to send me a private message in reference to this thread. I look forward to hearing from you!
Kristen A,
GM Customer Care
byrds6
FL
Im at a loss for my rear washer now. I have disconnected every section of hose to include the one behind the washer arm and water comes out fine. Air passes through the tube from the end of the arm and out but for whatever reason I can not get water to come out. Very odd indeed that everything seems fine other than the lack of water.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Are you saying you checked and the washer pump for rear is pushing water? I see you say the line is fine and all connected but what about the pump?
byrds6
FL
Pump is pushing water. Ive disconnected it as far as off the hatch itself and it pushes water out. The tube from the hatch to the blade will not push water out. However air passes through there so it doesnt appear clogged. Ive even tried putting a small needle in the hole where it comes out as well. I am completely stumped.
There is a clog there somewhere or the pump is not pushing enough pressure. The water at the hose just before it get to the wiper arm should be a good solid stream. When you used a pin you may have just pushed the clog deeper in there. Find and use compressed air to blow that all out.
byrds6
FL
I don't own a compressor. That's why I used canned air. I wish I could get to where the hose connected to the spout on the arm but can't. If I could I'd try to blow it backwards from there too. It's been a real pain tracking this. Had my son watch the back when I pressed the sprayer today and it sprays out from the hatch pretty good so I don't think it's the motor.
Sounds like the water getting there is no problem so the arm needs to come off and take to a shop where the rest of the path is blown out. Are you saying where the hose attaches near the arm is hard to get to?
byrds6
FL
Yeah the part that attaches in the blade itself. If I knew how to pull the hole arm off Id do it myself lol.
KDM72
I have a 2011 yukon wand my rear washer not working. I pulled the line on the back and nothing comes out. I can hear the pump running but no fluid. I have looked under the truck and no fluid any where. Can the pump be bad if I can hear it running? Thank you
Danny3737
It sure can. You either have some debris at the pump or a broken shaft in the motor
vsaravia
