rear door speakers to new headunit
NOVAhoe
Manassas, VA
I heard about this but wasnt sure if i was gonna have to worry about it but sure enough... anyways lol so im putting in my new head unit today and found out i need to do something about my rear door speakers, the harness i got from crutchfield doesnt have the wires for them and neither does the kenwood head unit i got, can i just splice the wires for the rear door speakers into the front speaker wires on the harness thats on the truck? i dont really care if i cant adjust the fade right when its in, as long as they work im fine with that
---------- Post added at 04:51 PM ---------- Previous post was at 04:39 PM ----------
ok i looked at it again and have more details, the harness in the truck has two light green wires for the rear speakers, the harness crutchfield gave me doesnt have a spot for those neither does the new head unit harness have the wires for it, so if i just cut the wires off the harness in the truck and spliced them back in with the rear door speakers it should work ok right?
NOVAhoe
NOVAhoe
Manassas, VA
that would be much appreciated, i think its the standard stereo, does that one have the 6 speakers also?
NOVAhoe
NOVAhoe
Manassas, VA
no i dont, scratch the bose then, i forgot they had the amps under the seat, so its just the regular stereo system
SunlitComet
OBS Jedi-Do Good
unknown at this time.
print this as soon as possible and try this:
Notes
79077971
Radio/Audio System Schematics (Base): RADIO and RADIO BATT Fuses, Radio, Speakers, G200
NOVAhoe
NOVAhoe
Manassas, VA
hmmm the speakers that dont work arent on there, was there any other stereos besides the bose and the base one? i know its factory though, for now i just wired them into my amp that powers my sub, but its only a mono block amp so they just have bass haha, but atleast it filled the sound in again, at least until i either get them to work with the head unit or just buy a two channel amp for them
Gzes
the drifting 2dr
Wichita tx
I would splice the rear with the front speakers because it works and it wont break. I've had to do that before and it's very easy and just use all the safety precaution so you don't damage your head unit.
jimni
London, UK
Don't know whats behind your dash or under your seat but this is what i found in my 96 tahoe. Hope its of some use.
To/From head unit:
FRONT DOORS: (Speaker and Tweeter)
LF-: Grey
LF+: Tan
RF-: Dark Green
RF+: Light Green
REAR ROOF: (these wires go to the speakers and also act as INPUTS for the amp)
RR-: Light Blue
RR+: Dark Blue
LR-: Yellow
LR+: Brown
Ground: Black
Display Dim : Purple/White (linked to interior lights dimmer)
Fuse Out: Grey
Amp Feed: Pink (runs to a relay. see below for more on this)
Fuse Out: Yellow (fuse 17 10A)
Battery: Orange (fuse 19 10A)
To/From Amp:
(the following wires are INPUTS/SOURCE for an amp)
RR-: Light Blue
RR+: Dark Blue
LR-: Yellow
LR+: Brown
(the following wires are all OUTPUTS which only feed the rear doors)
RR Door+: Red
RR Door-: Tan
LR Door+: Tan (this is not a typo; there are two tans but it's obvious which is which)
LR Door-: White
Relay Signal: Orange (this is your remote/trigger/accessory. it turns the amp on!)
Ground: Black (probably ignore this and connect your amp ground to a seat bolt)
There are so many opinions and plenty of different wire colour charts out there to aid you through installing your own system. If I'd have had this COMPLETE list it would have saved me heaps of trouble and hours of research. Hope it's right for your set up.
By the way... Don't look for a normal sized amp under the drivers seat. It's a small silver box that looks as though it's part of the seat mech. It literally pulls out.
craz-28
Hell....AZ
There was a thread on this not too long ago and also, when I got my new deck from Crutchfield it came with an extra instructions sheet for making the back doors work. If you have the standard stereo, you still have an amp under the driver seat. With the new deck all you need to do is tap into the power ant wire and in your original harness you will have to find the power wire that feeds the amp. 1 vampire clip and your done.
Now if you have the BOSE system....sorry, cant help ya there. :(
Update.....
What I found was that you will need to hook up the blue/white power ant wire to the blue wire in the original harness. This "should" be the power wire for the factory amp if you have one.
the big blue bus
richmond, va
i just ran the remote wire to the orage wire on the amp plug. what was weird was i got power when headunit was on tunner but any other it didnt do i ran the wire to it and now i got the doors back on all functions. when i made the new radio harness i noticed 2 wires that werent included in the new plug that i got so i assume they are for amp or something
wwiizz
