Rear Coil Ride a Bit Bumpy
Milz77
All,
Looking for input on above. 2013 Tahoe LT
I got the 4" 5305 Belltech drop coils with same Belltech SP shocks but I have a 2" spacer currently for a 2" rear lift and back end is bit bumpy. I don't want to lower any more than it currently is as I need rear travel. Mind you have I have 295/35/24 tires and rims but was wondering if anything I can do to make rear bit smoother driving. I have over 2" clearance from bumpstops and frame so it is not bottoming out by any means.
Any way to get a more forgiving rear coil?
Thanks for input and suggestions!
NORCAL SS
SUV SUSPENSION GURU
295 35 24 will hit the suspension harder. is the swaybar pointing down?
Milz77
Milz77
No it is running parallel with body and not perpendicular. Is this not correct set-up?
NORCAL SS
SUV SUSPENSION GURU
you relocated the drivers side bracket on axle correct?
also endlinks are max 30 lbs
Milz77
Milz77
Sway are I bought from you for 2013 Tahoe didn't have any relocation brackets. Is this something I need to do or not required. If required what do I need to do or modify?
curbud
