Rear bumper removal to get at rust.
Stimpy911
There is a small rust line starting above the back bumper on the left side. Is that section of the bumper easy to undo and drop down so that I can remove the rust?
Trailblazzin
Lancaster PA
You can take the entire bumper off pretty quickly.
Couple bolts and clips and it’s off. I removed the taillights but not sure if it was necessary.
S
Stimpy911
Forgot to say thanks
PG01
Up here to the right
No removal of tails necessary, couple of 7mm on the liner each side, 2 10mm under rear by spare pull out from each each wheel well at quarter panel, diconnect back up sensor harness(if you have them) and slide it right off. There is a plastic rail bolted to metal under lip of quarters that hold bumper to truck.
sanco
Chicago
be careful with that rust spot, on my 07 I started working on what I thought was a quarter size section that was bubbling slightly and it turns out it was a softball size section that rusted out with a 2" section that was completely about to fall off. Few months down the line it started to come right back.
S
Stimpy911
Gotta try something unless I see what a body shop can do.
veteran111
