West 1
- Joined
- Jan 20, 2023
- Posts
- 705
- Reaction score
- 1,522
Damaged OEM bearings, axle shaft shows identical marks inside where bearings run
Second photo of damaged OEM bearings
Third photo is New Timken on Left, damaged OEM bearings showing the back un damaged side on right.
I am rebuilding the rear Differential on my 08 Denali. Main complaint is a rear axle whine while accelerating. I plan to install all new bearings, Pinion, Carrier and Axle along with a rear brake job as part of this repair.
Before tear down I was hoping my noise would be found to be a Pinion Bearing failing. I don't have them out yet but pulled both axles and the axle bearings. Found the Pass side had a seal leaking at the axle bearing.
Pulled both axle bearings and found the same odd marks on the outside of the bearings and in the axle tube, both on the TOP of the housing facing the roof of the car????
I worked for a bearing manufacturer for 30 years, saw lots of bearing failures and normal wear bearings over the years. Have never run across this type bearing damage.
I took a couple pictures of the old bearings showing the wear and the opposite side showing they look perfect. All the rollers show no wear I have found?
The new bearings came in, Timken, still Made in the USA. I was shocked thought for sure they would be China made.
My only guesses would be that someone Welded on this vehicle while these bearings were in the car and the weld grounded through the bearings? If it was from going over a hard bump while driving I would expect differing damage side to side?
I will pull the pinion bearings out for inspection next then the carrier bearings, I have new replacements ready to go.
The last thing I am worried about is the Ring and Pinion gears. I am concerned they may have been damaged due to the leaking axle seal lowing the oil level? Noise on Tip in is normally gear noise not bearing noise? My noise did not change in pitch while turning left or right and goes away when you let off the throttle. I have ordered a new Ring and Pinion set so I will be prepared if that is needed. At this point I am wondering if I should have purchased a complete axle assembly to drop in.
Curous what you guys have seen in the past.
