Random Misfire after Overheating 2013Yukon Denali 6.2L
13UpInSmoke
Ok so about 2-3 months ago I ended up overheating my truck while driving around town. Cant believe I didnt see it but is what it is. Previously I have swapped the radiator, upper & lower hoses, heater hoses & bulk head connections, water pump, thermostat & full flush. When I did all of that I had one of the heater hose replacements with the Dorman metal/aluminum connections didn't seat correctly & wouldn't hold the seal so I swapped that one hose back to the stock with the intention of going back & fixing it later. Course that didn't happen & its what failed completely. So I get the truck back to the house limped it home with gallons of water & some hose crimps. Once I got the hose fixed correctly, refilled the cooling system & cleared the codes the truck will run fine but then every once in a while I will get a P0300 random misfire. Sometimes the trac & stability go off as well, the truck will shudder & run kinda ruff for a minute & then it goes back to normal & the check engine light goes off. I have done the head gasket check with pump & fluid thing that goes on the resevoir. Ive also pulled the plugs & checked gaps & looking for any impacts on them & they all checked out. Along with doing a compression test. All cylinders between 200-212 psi. What am I missing? Bent valve or push rod maybe or something else?? I'm stumped. Truck has about 150K on it.
j91z28d1
is afm active? if so it possible with the over heat that the lifters aren't happy and one is sticky coming in and out of 4cyl?
solli5pack
Any smoke coming out of the tail pipe on first start up of the day?Is the coolant level dropping with no visible signs of a leak? Reason I ask is my wife overheated our Burb that eventually caused a head gasket failure that turned into a misfire on I believe was cyl 4. Coolant would leak slightly onto the plug overnight but would burn off when I started it in the a.m. I had the misfire code and the traction control lights and all that until the coolant would burn off. I did all the compression tests and coolant system test and everything came back fine. I guess because it was a slight leak. I ended up using the opportunity to do a DOD delete.
These Gen IV 6.2s are known for dropping a valve guide when they overheat. Usually cylinders 7 and 8.
I reckon the only way to check that is by camera.
13UpInSmoke
13UpInSmoke
No no smoke & the coolant is staying at the same level
13UpInSmoke
13UpInSmoke
So would it still run ok with dropped valve guide? And am I sticking the camera in the spark plug hole or am I looking in like the intake runner?
mikez71
I agree with Fless, get a good scanner on it.
Can it still have good compression with a dropped guide?
Kind of sounds like it might be electrical.. Plug wires? Dirty grounds?
j91z28d1
my camera, I think he means a bore scope.
I bought this one for home and use it more than I thought I would. I have one at work that costs way more but isn't nearly as useful.
you can go in thru the spark plug hole, and turn it up to look at the valves.
solli5pack
I would say definitely get a scanner and find out what cyl or cyl's are misfiring and then start planning next steps after that.
13UpInSmoke
13UpInSmoke
Ok so finally got around to hooking up the tech2 to watch misfire & these are the pics I took from today. Cylinder 1 seems the biggest culprit. Not sure if that's what's causing the occasional misfire from the others. Weird thought that I took a 6 hour drive to Atlanta sitting in traffic for a few hours & nothing happened. Truck ran great there & back. But as soon as Im driving back around town the misfire will randomly pop up. So the 9000 were when I started logging today, & ended with the 12000. Its weird though that it does it for a minute or 2 then back to normal & runs fine
Guess Ill get in there with a camera & see what I can see this week
13UpInSmoke
13UpInSmoke
Ok so I swapped coils with #1 &. #3 and the misfire followed the coil. So new coils. Should I just replace the one or do them all? And do I go with like an accel or granatelli vs stock if replacing all?
j91z28d1
when I bought my truck it had one replaced. I think it's ok to just do one.
I think probably oem would be the best from rock auto, that's the standard recommendation but I've had horrible luck with oem gm parts being no better than anything else lately.
good luck!
13UpInSmoke
13UpInSmoke
I grabbed a car quest premium coil from advance auto real quick. Swapped it in & so far today running the rest of my errands it seems to be running pretty well again. I also grabbed a other set of plugs but may wait until I do the cam in the near future & swap them in if the coil fixes my misfire
petethepug
Michael
SoCal
Nice detective work. I’ll betcha the coil didn’t like getting sprayed with coolant when the heater hose went.
Dh1280
