Random Electronics Questions
Jayhawkeye3
1. With the native google maps, can you change to satellite?
2. Can you set the fog lights to default on?
3. Where on earth is the current gear displayed on the driver display?
Edit: sorry, 2025 Yukon Denali diesel
Jay P Wy
Navy
Natrona County WY
#2 would require a change in the BCM programing or custom wiring. #3 are you asking to see the actual gear it's in? If so you need something like Banks iDash or Edge CTS to see that.
Jayhawkeye3
Jayhawkeye3
That’s absolutely insane. My 2012 and 2018 vehicles allowed me to see my current gear and set my fog lights to default on.
Yikes.
rlhmarines
Senior Member
Marine Corps Supporting Member
The gear indicates only while in manual mode meaning you can hit the L, for low gear, on the steering and this will display your current selected gear which you can then adjust up or down with the + or - paddles on the backside of the steering wheel. This can also be used to lockout gear hunting by the transmission especially while towing if you’re not in tow hall mode.
Tupapi
