Add To Driver Display
nomech
While looking at gauges and other information on the center screen, I noticed that you can add certain gauges to the drive display, it replaced the default date/time/temp. While this is very straightforward, it seems that I can only have 1 item on the driver display. Meaning, I can add the tire pressure gauge but if I want to add the trip gauge the tire pressure gauge goes away. While I wasn't expecting them to be displayed at the same time, I assumed I could cycle between them. I thought this was doable because once you tap to 'add' a display when you add another gauge and go back to the first gauge, it doesn't have the 'add' option meaning it is already added, but I can remove it.
How is it that I can add multiple gauges but I can only get a single gauge to appear and I can't figure out how to rotate between all the gauges that I 'add' to the driver display?
2025 Tahoe.
Thanks.
rlhmarines
Senior Member
Marine Corps Supporting Member
I haven’t played around with this yet like I did on a rental ‘24 Silverado but I know you can cycle thru different clusters (DIC) so maybe try on one of the lesser populated cluster screens to see if it’s possible to add more than one, might be worth a look see.
NWLa Now
NW La
Very underwhelmed w/ the customization choices in my ‘25 Z71 w/ HUD & after 6 months it’s not my lack of system operation knowledge.
That said really like the larger Infotainment screen added to ‘25s + the tranny selector stalk back on the steering column so they sorta offset the DIC choices.
E_S_D
I leave the one I want to see the most on the left side of the DIC, if I want to see any of the others I switch to the info screen and cycle through them there.
N
nomech
To the left? Which screen are you using as the main screen? My main screen is the one that shows most of the gauges and the tire pressure monitor (or whichever one I set) is set right in the middle of the display.
E_S_D
This one (stock photo from the internet, but the same layout I use)
rlhmarines
Senior Member
This is the gauge cluster display that I use regularly but I haven’t played around with adding or modifying this display.
I use a quick sticky tab for trip info on the infotainment screen so that I don’t need to have it on my DIC screen.
N
nomech
This is the gauge cluster display that I use regularly but I haven’t played around with adding or modifying this display.View attachment 455227I use a quick sticky tab for trip info on the infotainment screen so that I don’t need to have it on my DIC screen.
Yup, that's the view I use. When you click to add a screen to the driver display, it replaces the middle section where you see the time, temp and date. I was hoping to get left/right or up/down options when I added more screens. For example, oil life, trip 1, trip 1 and tire pressure. Also being able to go to the default option (date/time/temp) as you are scrolling through would be nice.
Another annoyance on this screen is having two gas gauge symbols on the bottom left.
One other thing I figured out is that if you are listening to the radio and have the nav in the full screen option (on the center screen) and you cycle through the radio presets, you don't see which station/preset you are on. You need to split the center nav screen or I suppose you can add the radio as one of the pop up screens in the main driver display, but I don't want to take up the entire middle section for a radio display.
N
nomech
This one (stock photo from the internet, but the same layout I use) View attachment 455226
I see the left right arrows so it seems that in the 2023 model you can add more screen and cycle through them. My 2020 had all the options visible in the driver display from the factory. I remember scrolling through trip 1, trip 2, tire pressure, etc...many options.
KMeloney
2025 Tahoe.
Thanks.
Are you still having a problem with this? What you need to do is set up what info you want to see all of the time in the left and right side of the display. I have my tires' PSI displayed full-time on the left side of the screen, and the time and temp in the right side of the screen. Then, if there's something like fuel economy or trips or something like that (I've got my center section showing the music I'm listening to -- so that I can have Waze on my Nav and be able to see what song is playing without moving off the Waze screen) in the middle section.
Now, you can't put everything offered for the center part of the screen to the left or the right, but you CAN put the tire pressure full-time to a side AND have the time and temp on the other side. You CAN NOT put what music is playing, for example, in one of the side displays.
So, there are limitations to what you can put in the sides, but there are some options (including the option to do what you said you can't do).
KMeloney
I've got a '23 Denali, and I don't think there's a way to have two gas gauges on my screen at once. But, yeah, that would be unacceptable to me, too.
N
nomech
I don't follow what you are saying, I use the main display, which shows speed on the left and RPMs on the right. The center is where you see the 'add to driver display' item, which I can only get 1 item in the center. I can select multiple items to 'send' to the driver display, but I can't figure out how to cycle through them, assuming there is a way, but maybe there isn't.
Which is why I'm confused, because if I send the PSI and the oil life, I can 'remove' both of those from the driver display, which is the only option I have after I've 'sent' it to the drivers display, meaning I know two items are set to be sent to the drivers display, I'm just not sure how to get them to cycle.
N
nomech
To be clear, it isn't two gas gauges, it is two gas symbols with the arrow showing which side your gas door is on. They are both in the bottom left when I'm on my 'main' screen. Not sure if you see two on the other screens as I don't use those.
StephenPT
St. Helens, OR
Two different Digital Cluster systems are being talked about here. The OP has a '25, which is a new display and new software. KMeloney and another poster are mentioning their '21 to '24 digital dash. Completely different systems.
@nomech - I see your frustration with this system. I have a '22 YXL and I like scrolling up and down through various info i.e. tire pressure, fuel economy, Trip 1&2, DEF Level, etc. The clowns that designed the '25+ digital dash took away that feature. You can only send one info "card" to the driver display. There is no way to have multiple info cards in the cluster. If you want to see other info, you have to go to the infotainment and that is a complete blunder on GM's part. Not to mention the nonsensical use of two fuel symbols right next to each other. One to indicate fuel level and fill side and the other to indicate distance to empty. Maybe OTA updates will clean up some of this in the future, but I don't think there's much they can do about scrolling through multiple info cards in the cluster because there's no button/wheel on the steering wheel that could be used for that...
N
nomech
I know OTA is over the air, but are these automatic or would I need to go into infotainment and force a check/update?
KMeloney
Right, not gauges, but icons. I used the wrong term, but my sentiment remains the same. It looks really stupid.
Also, it’s now clear to me that the ‘25’s cluster doesn’t function like mine, and so you should ignore what I wrote about it [and the way mine operated]. It sounds like the ‘25’s is a step backward, at least as far as personalization of it goes.
StephenPT
St. Helens, OR
The update will download in the background. When it’s ready to install it will prompt you when you put it in park. You can then accept the update and it will start the update. You don’t have to stay in the rig while it updates - usually takes ~10min
rlhmarines
Senior Member
Yes, 2 different fuel icons, lower icon references remaining fuel range and the icon above reflects fuel tank location and fuel level.
The older models did have a different design and overall feel to the many possibles DIC configurations that were available.
N
nomech
Yes it looks strange to me. They could have removed the fuel icon for the miles remaining moved the mileage to the left and after mi add remng or some other abbreviation.
rlhmarines
Senior Member
At first it threw me off also but I’ve gotten use to it being there.
TexasTaz
