Add To Driver Display
NWLa Now
NW La
Can anyone that has a 2025 Tahoe advise if they can program the left or right DIC screens to display specific information? I have 5-7 factory pre-set DIC display options, none are customizable & the last one shows the speedo in the center but left & right are blank. Would be great if I could program those to my choices vs. OEM but not optimistic it’s possible.
rlhmarines
Senior Member
Marine Corps Supporting Member
I believe at the moment what you’re asking for is not possible but it could be in a future over the air (OTA) update from GM, especially if we complain or request it enough to customer service support.
BacDoc
Vero Beach Florida
As a couple others have posted, the 2025 display is different from the previous years and maybe a step backwards. I have the 2024 and it is very customizable and easy to change the left and right gages to what you want and the center is pretty easy to scroll through or set up a default.
I like the way the 2025 screen is larger and flows better into the dashboard but I like the dashboard and HUD display section of the 2024. If they kept the options of the display the same as the previous model that would have been the better way to do this.
N
nomech
There is a button above the volume up/down button and a button above the favorites up/down button that don't seem to do anything unless you are in a certain mode (the two buttons I'm referring to are labeled + and - respectively).
It would be nice to have those buttons cycle through the center driver display section if you are not in the 'mode' where the buttons are active.
NWLa Now
NW La
fellow cyclist totally agree w/ both of your paragraphs & the 2nd would be optimum IMO.
agreed w / both paragraphs but having been in the industry I’m not optimistic the 2nd will become reality but one can hope right?
dzuczek17
I am having the same issue. There is a way to add the trip information from the main infotainment system by going to the controls tab and clicking on the gauge and then selecting "add to driver display". But I cannot figure out how to revert to having the time, date, and temperature tab back once replaced with the trip info.
N
nomech
It appears you can only have one thing at a time and there isn't a way to add additional 'tiles' with the ability to cycle through each tile.
N
nomech
To be clear, it isn't two gas gauges, it is two gas symbols with the arrow showing which side your gas door is on. They are both in the bottom left when I'm on my 'main' screen. Not sure if you see two on the other screens as I don't use those.
I have an update here, while the icons have not changed, at least now I have an answer as to what the 'second' gas icon is there for, it changes to orange (I believe) when you are low on gas. I almost never let my tank run that low so I only noticed it one time. I don't think this validates the second icon right under the gas gauge which has the same gas icon, but at least it does something.
NWLa Now
NW La
Exactly my experience after a yr+ w/ a ‘25 Z71.
AZPatriot1963
