randeez
needs a lot for e85, hoping it will keep stock short block alive for a while - which im doing a terrible job at right now
and thats where this table comes in, i have plenty of injector to run at lower than 58psi and still flow enough. right now fuel pressure drops to low 30s psi so i know if "commanded" pressure is lower than actual pressure the ecm will do its thing, so long as the pressure reading is accurate. I think i will start with having the regulated pressure around 50psi (1:1 boost referenced also).
