Hi.
I have just finished swapping the brakes on my 04 Tahoe 4wd. I have changed disks, pads and calipers.
I mounted the new calipers on the car before mowing the brake lines. After that I opened the bread valve until fluid came out. When all the brake was done I bleed all the calipers wit my wife at the pedal and me with a bleeder hose into a bottle with brake fluid. We started from the corner furthest away from master cylinder. I always made sure that the brake fluid was topped up.
The problem now is that only the front right will block when flooring the brake pedal. I can feel that the left is braking but it won’t block.
What could be the problem?
HD
HD
